how to encode 25 fps ? progressive , interlace , 3:2 pulldown playback.
how to encode 23.976 fps? progressive , interlace , 3:2 pulldown playback.
to get a dvd with no errors!
i want 29.97 NTSC
If you have 23.976 material, resize to 720 x 480, encode at 23.976 fps and apply 3:2 pulldown afterwards (DGpulldown if your encoder can't do it for you). Author as NTSC and you will get 29.970 fps playback.
If you have 25 fps material then resize to 720 x 480, encode at 25 fps, then use DGPulldown to apply a custom pulldown 25fps -> 29.970 fps. Author as NTSC and you will get 29.970 fps playbackRead my blog here.
This will allow all my dvd to play on dvd player with no errors right?guns1inger
PostPosted: Aug 17, 2009 20:25
My encoder does allow 3:2 pulldown i am using TMPGenc 4.0 xpress
So for 25 fps material i have to encode first then use DGPulldown and apply a custom pulldown as you mentioned?
25 fps -> 29.970
Thanks -
Probably, but nobody can give you a 100% guarantee becauseOriginally Posted by mrjust
1) Some DVD players are crap and they won't play discs that they should play.
2) You might do something wrong in the process and not know it and then you blame the player when it's actually your fault.
3) You might use poor quality media that your player doesn't play well or at all.
4) You might do something like forget to finalize the disc and that won't play.
5) If you are burning to dual layer media and even if you use Verbatim DVD+R DL discs and do every step correctly and burn it correctly and finalize it, your player still might refuse to play it as some older players won't play the second layer of any consumer burned DL media.
If you are afraid, just burn to DVD+RW or DVD-RW. If that works you can then burn to DVD+R or DVD-R. I am assuming here that you are not using dual layer media, but if so, see warning #5 above. -
You sure? isn't there a '"Playback 3:2 pulldown" option in the MPEG output settings"?Originally Posted by mrjust
im using SONY DVD-R and no im not using any dual layer media as i always end up having errors with them!\jman98
i bought verbatim dl dvd+r and it wouldn't play right on dvd player.
i burn my dvds with IMGBURN
i believe you read my question wrong because tmpgenc does have 3:2 pulldown playback.MysticE
Combining videos with different fps
By michn in forum EditingReplies: 4Last Post: 4th Apr 2011, 06:55 -
Problem with subtitles in videos of 23.976 fps
By sgbd in forum Authoring (DVD)Replies: 5Last Post: 7th Nov 2010, 18:56 -
Youtube and conversion of 60 FPS videos
By CursedLemon in forum Video ConversionReplies: 3Last Post: 14th Sep 2010, 08:07 -
How to encode audio to different fps?
By mrjust in forum Newbie / General discussionsReplies: 9Last Post: 16th Mar 2010, 21:07 -
Oppinions on encode please, 960x600 30 fps to xvid or ?
By Fenlock in forum Newbie / General discussionsReplies: 11Last Post: 18th Aug 2008, 16:22
