I am working on a project that will be rendered to a WMV file and will also need to be onto a DVD. My original footage is 720 X 480 NTSV DV SD 29.97fps, 4:3 aspect ratio.
When I export my WMV file, I don't know if I should use 29.97fps or 30fps (I think Vegas 7 will creates this file as progressive). The frame size of the WMV file will be 656 X 480. I chose 656 X 480 because I want my 4:3 video without black bars on top and bottom. This WMV file will not be played on the web. The file will be played back within Windows Media Player or from within MS PowerPoint.
When you create a WMV file out of Sony Vegas, is it automatically progressive or does the project properties determine if it's interlaced or not? For example, the "deinterlace method" is currently set to "blend".
Use 29.97 fps. Computers will handle it.Originally Posted by bdr13278
WMV is always progressive. Use VC-1 if you want interlace as an option.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
WMV3 (VC-1) supports interlaced encoding but don't count on anything anywhere to handle it properly.
DVDSubEdit error. 30fps instead of 29.97 for SRTs
By cal_tony in forum SubtitleReplies: 3Last Post: 12th Apr 2012, 21:59 -
30fps --> 24fps WITHOUT pulldown
By agni451 in forum Video ConversionReplies: 4Last Post: 4th Apr 2012, 23:25 -
Pulldown? when Encoding a 29.970fps progressive AVI to NTSC DVD
By FulciLives in forum DVD RippingReplies: 5Last Post: 27th Feb 2012, 20:00 -
Converting 30fps to 29.97fps ?
By blewyn in forum Video ConversionReplies: 2Last Post: 19th Mar 2008, 11:24 -
Converting from 120fps to 30fps
By shorto in forum Video ConversionReplies: 6Last Post: 22nd Feb 2008, 12:51
