    Jan 2009
    I have some .AVI files that get thrown out of sync whenever I edit them with a program like Windows Movie Maker or AVS Video Editor. When Open these files in Virtualdub, I get a message saying:
    "[!] AVI: Stream 0 (video) has a non-zero start position of 2 samples (+67 ms).
    VirtualDub does not currently support a non-zero start time and the stream
    will be interpreted as starting from zero."
    What should I do?
  2. Probably just ignore the error. You might have to adjust the audio with VirtualDub's audio skew function. My guess is if you open the AVI file with VirtualDub, select Video -> Direct Stream Copy, maybe set the audio skew, then save as AVI, your other programs will handle the results (assuming that's your goal).
