How can i speed up my Rendering in Sony Vegus Movie 8? It takes ages to render videos, going from 0%, 1%, 2%...99%, 100% etc.
Is it related to computer memory Ram?
Does increasing computer RAM speed up Render speed?
Results 1 to 10 of 10
Usually not. Unless you have so little the system is swapping virtual memory all the time. I'm not familiar with Vegas' memory usage. 512 MB may be a bit low though. Memory is pretty cheap so upgrading to 2 GB won't cost much. CPU power is usually the most critical.Originally Posted by Entry
something is probably wrong with your settings...
What are you rendering? Standard definition material for DVD? High def material? How long is it taking?
Increase memory to at least 1GB but 2GB will have some benefit.
Otherwise it is your Athlon 1800 CPU. A Core 2 Quad would up performance about 6-7x.
Vegas allows multiple machines to process effects/filter renders. Also Vegas allows running multiple instances so you can continue to work during a render.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
You can open taskmanager while you are doing this task, and have a better idea of memory usage / swapping , and if it plays a role in the performance you are experiencing
Ages? How Long?....Be aware that rendering IS a slow process by nature. Sure your hardware can speed it up, but there are no 'shortcuts' that you can take. Certain things like effects heavy work will never be quick. Although if your talking hours for a few minutes of SD video, then yes that is slow!....Be more specific about what your doing and how long its taking.
yep your system is pitiful for video rendering..the good news is you have lots of room for improvement..you just gotta pay for it
Matey - don't know if this will work for you, but it sped up my DVD authoring with VS10 by a factor of 100...
i use DVDpatcher to "fool" VS10 into thinking the video is DVD compliant - so it skips the re-encoding part....
cheers,
Sony Vegas Pro mpeg rendering size larger than movie studio
By bbbbbbb45 in forum Newbie / General discussionsReplies: 2Last Post: 17th Jan 2012, 13:31 -
Whats is best HD option for rendering with Sony vegas movie studio HD?
By Sevy in forum Newbie / General discussionsReplies: 6Last Post: 17th Oct 2011, 16:57 -
ffmpegX taking LONG time
By macgurl in forum ffmpegX general discussionReplies: 1Last Post: 23rd Apr 2011, 01:50 -
SONY Movie Studio Platinum 10 rendering problem!
By EagleW in forum EditingReplies: 4Last Post: 4th Nov 2010, 18:52 -
Sony Vegas Movie Studio 10 rendering problem
By videogirl214 in forum EditingReplies: 1Last Post: 19th Aug 2010, 00:29
