Hello,
I captured footage using Vegas 9 Pro as HDV from my Sony HDR-HC3 camcorder. Then I edit some of the media to split and remove unwanted footage. When I join on the timeline and add crossfade, transition or Fx event, the preview shows some of the end/lead frames I cut from the media before joining. The unwanted frames are not there if I do not add the effect, but the transition is rather abrupt.
Is Vegas cutting on a frame group, in which case there would be some unwanted left over video material when joining. Or is it because of the MPEG coding that spreads video information across several frames.
I've searched most forum topics related to Vegas Split, but could not find a good reference to solve this problem.
Thanks,
Boris.
HDV is long gop mpeg-2. you might want to save out the cut pieces separately and then import them to make sure your edits stay where you made them.
Thanks for the suggestion. I'm editing on the timeline, so to save I would need to render and re-import the clips, which is a lengthy process. In any case, I would have thought Vegas should be able to fix this without workarounds. It sounds like I need to get on their support line.
I got this advise from Sony HDV forum:
"Well, remember, in any editor, when you add a crossfade or any other transition you are "overlapping" the clips, so the transition must use some of what you previously edited out to make that transition happen. If your transition is 15 frames on either side of the cut, you need to first trim both clips by 15 more frames.
So if you want ONLY those frames you kept to be visible, and no others during the transition, mark the Out Point of the first clip 15 frames sooner and the In Point of the second clip 15 frames later, assuming you have a default 1 second (30 frame) transition. This way the very first frame of the second clip that is visible in the dissolve is a "wanted" frame, not an "unwanted" one. And the same would hold true for the end.
Otherwise it's not a transition; it's just a cut.
So it has nothing to do with either GOP or MPEG encoding."
Problem soved
sounds more like a workaround for a bug. that isn't needed for separate clips as the transition starts with the 15th to last frame of the first clip and ends with the 15th frame of the second clip.
Sony Vegas Pro 10 Crashing to Desktop when loading HD footage
By xX-Towrd01-Xx in forum EditingReplies: 3Last Post: 3rd Mar 2012, 14:08 -
Footage captured in Sony Vegas compatible with Adobe Premiere Pro?
By snoutproductions in forum Software PlayingReplies: 15Last Post: 21st Jan 2012, 10:28 -
How to control transition length in Vegas Pro 10?
By gutterboy in forum EditingReplies: 4Last Post: 14th Oct 2011, 15:12 -
Sony Vegas Pro 8 - Adding VideoFX to many video clips at once.
By jnaizer in forum EditingReplies: 2Last Post: 30th Dec 2008, 20:28 -
Mixing HDV and AVCHD in Vegas Pro 8
By SCDVD in forum EditingReplies: 0Last Post: 9th Jun 2008, 18:29
