I did some research and found out that I didn't need a gigabit router, just a gigabit switch, a $35USD D-Link from newegg
http://www.newegg.com/Product/Product.aspx?Item=N82E16833127083
My router will feed my daughters PC in the basement, and also feed the switch I am about to purchase to use as a high speed bridge between my 2 PC's w/ OB gigabit ethernet
I was warned that when you connect a gigabit switch to a 10/100 router that the switch may default to 10/100 on all connections, but that was the older less sophisticated switches, I called D-Link up on the phone and asked them and they verified that I can bridge my 2 PC's @ gigabit speed w/ their gigabit switch and then connect the switch to my 10/100 router w/ out it defaulting to 10/100 speed on all ports
ocgw
peace
Results 31 to 43 of 43
i7 2700K @ 4.4Ghz 16GB DDR3 1600 Samsung Pro 840 128GB Seagate 2TB HDD EVGA GTX 650
https://forum.videohelp.com/topic368691.html -
I have mine hooked up through a Netgear gigabit switch. Router to computer is switched as 10Mb/s where computer to computer is connected gigabit. That is the way a switch is supposed to work.Originally Posted by ocgw
A hub will default everything to the slowest connection. Don't use a hub.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Do you think I will need a crossover cable?Originally Posted by edDV
ocgw
peacei7 2700K @ 4.4Ghz 16GB DDR3 1600 Samsung Pro 840 128GB Seagate 2TB HDD EVGA GTX 650
If you're just connecting computers and a router to the switch you don't need a crossover cable.
I think most GbE devices support Auto-MDIX so there shouldn't be a need for crossover cables any longer. The devices are smart enough to know which sort of connection they should have.
FB-DIMM are the real cause of global warming -
Yes they auto sense now. I still have a couple of crossover cables just in case.
Then it's done
thx for the responses
ocgw
I ended up going w/ the 8-port D-Link Gigabit switch rather than the 5-port D-Link Gigabit switch
http://www.newegg.com/Product/Product.aspx?Item=N82E16833127082
The 5-port was $39.99USD-$3.99USD instant rebate, $10USD mail-in rebate and $1.99USD shipping
The 8-port was $49.99USD-$10USD instant rebate, $15USD mail-in rebate and free shipping
Making the 8-port actually a couple of dollars cheaper
additionally....
The 5-port has 112KB per device buffer memory
The 8-port has 144KB per device buffer memory
ocgw
This DLink 8-port from Amazon is the one I gotl!
http://www.amazon.com/gp/product/B000FITKK8?ie=UTF8&tag=thdifa-20&linkCode=as2&camp=17...SIN=B000FITKK8
Only $39.99 for that one, and it also has the $15 rebates!
I've had trouble with Newegg rebates before. (Verbatim DVDs, anybody?)
No problems from Amazon.
Also grabbed a few $16 Gigabit NICs.
hmmmm......I'm not sure if it is fair to knock newegg if you don't get a rebate from a product they sold you, I would think the blame resides w/ the manufacturer that offered the rebateOriginally Posted by lordsmurf
ps. looks like we got the exact same switch for the same price
Did you have to pay for shipping LS?
ocgw
Got my 8-port gigabit switch today, plugged it in, 2 seconds later it was working w/o any config on my part
averaging 49MB/s sustained transfer rate
transfers SL DVD in a minute "and some change"
ocgw
Newegg charges tax where I live, simple as that.
Amazon free shipping.Want my help? Ask here! (not via PM!)
ouch!Originally Posted by lordsmurf
ocgw
Do I need a Gigabit router for live streaming?
By jbaugh in forum Video Streaming DownloadingReplies: 11Last Post: 19th Nov 2011, 18:32 -
Need advice about purchasing new gigabit router
By videocheez in forum ComputerReplies: 7Last Post: 21st Aug 2011, 11:11 -
using PS3 media server for gigabit file transfer
By GLE3 in forum ComputerReplies: 11Last Post: 29th Apr 2011, 11:29 -
Which ethernet card do I need?
By capman21 in forum ComputerReplies: 4Last Post: 10th Feb 2011, 01:11 -
Gigabit LAN speed
By kurbads in forum Newbie / General discussionsReplies: 4Last Post: 11th Aug 2007, 05:33
