ive have just had to rebuild my laptop and down loaded the latest version of SVCD2DVD from there site and it seems to install but when you go to open it fails? is there a patch and fix for this???
As you have vista - can you take a look at this thread about installation and Vista issues?
https://forum.videohelp.com/topic324278.html#1776530
(In particular: installation in a folder other than "Program Files" and running "As Administrator")SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
ok in which folder is it installed?
SVCD2DVD 2.5.5030 Not Working with Vista SP2
By k_vic in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 28th May 2009, 12:33 -
svcd2dvd not loading aftere service pack 1 vista 64bit
By lindakay in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 18th Apr 2008, 04:23 -
SVCD2DVD Vista problems
By blondeguysteve in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 8th Nov 2007, 09:35 -
svcd2dvd with vista
By nigeltheparrot in forum SVCD2DVD & VOB2MPGReplies: 17Last Post: 8th Jul 2007, 06:16 -
svcd2dvd / vista registration issue
By simonlee in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 24th Jun 2007, 14:54
