I captured "Dracula", the 1931 version with Bela Lugosi. I downloaded the subtitles for it, but when i used VirtualDubMod to subtitle the movie, the subtitles and movie were out of sync. Any way to fix so they are in sync?
Thanks!
You'd probably have to manually edit the timing for each line. Are the subtitles all off by about the same amount of time? I don't know if there's a feature in any of the subtitle utilities that can automatically shift all the times forward or back by a certain amount of time, but one of more of them probably do have a feature like that.
Are you sure the subtitles are for that exact version of the movie, and not for, say, a DVD version, which might have additional scenes included? Does the running time of the subtitles roughly match the running time of the video?If cameras add ten pounds, why would people want to eat them? -
Thanks for your help, but i tried Subdownloader and i found subtitles to match my movie. Everything is great, they are sync'd perfectly! Thanks again!Originally Posted by Ai Haibara
Multiple .srt subtitle files in a Divx movie
By sam9s in forum SubtitleReplies: 6Last Post: 13th Feb 2015, 16:34 -
VHS player connected to PC - all captured footage out of sync!
By kingmustard123 in forum Video Streaming DownloadingReplies: 2Last Post: 30th Jul 2011, 16:23 -
The timing between movie and subtitle is bad. can I fix that?
By Codonauta in forum SubtitleReplies: 4Last Post: 28th Dec 2009, 14:39 -
How to fix audio sync mid movie?
By 007craft in forum AudioReplies: 3Last Post: 8th Mar 2008, 12:55 -
Creating a Subtitle File(.sub or .srt) With Just Text(no time sync yet)
By Digistras in forum SubtitleReplies: 3Last Post: 20th Dec 2007, 16:31
