I´m considering bying the videocamera Flip Ultra HD which uses the format HD. Is it hard to convert HD-files (avi, mpeg 4) to SD-files before editing the files in a computer program?
Short answer : No.
Long answer : Why ? Converting to SD to edit entails a re-encode. Editing and then outputting entails another re-encode. Every re-encode costs quality. You would be better off editing in HD, then outputting to whatever format you need afterwards.
The Flip records in 720p, not full 1080, so you should be able to edit it's files on your system without too many issues.Read my blog here.
I´m editing with the program Adobe Premiere Elements 2.0 and I dont think that this program accepts HD-input files but I am not sure.
I would seriously consider budgeting for something that will handle editing in HD, or you lose any benefit that comes from getting an HD camera. You will lose a lot of time and quality converting down to SD before you even get to edit anything.
Read my blog here.
OK. I have also Adobe Premiere Elements 4 which can handle HD. Thank you for your respons.
I'm using TMPGEnc Xpress to edit my .mp4 clips from the Flip UltraHD and it works great! If I want to make a DVD, I encode to mpeg-2 with it and use Video Redo TV Suite to author.
Is there a loss of quality if I use the SUPER-program to convert a MP4-file(853 kb) to an output mpeg-2-file (4,87 mb) or an output avi-file (2,68 mb)?
Mixing video from Flip Ultra HD with other formats in Vegas Pro
By stantheman1976 in forum EditingReplies: 13Last Post: 19th Feb 2011, 11:10 -
FLIP Ultra HD - sloooow!!!!!!!!!!!!!!!!!
By jellybean3009 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 12th Apr 2010, 04:54 -
flip video ultra hd to dvd
By catchum in forum Newbie / General discussionsReplies: 1Last Post: 1st Feb 2010, 06:04
