I just can't figure this out. I have no problems creating a dvd. I save it as a mpeg and it looks fine . However when I burn it to dvd,the video goes back and forth from looking good to being heavily red tinted or red hue.It goes back and forth from being fine to the red hue. Everything becomes as if you turned up the hue to reddish. It's really got me stumped. Is it my hardware?My capture card? I've had this trouble using 2 different video editing programs. Has anyone encountered this ? Thanks I cant attach a example because it looks fine in the mpeg file.
Are you outputting NTSC?
What authoring program are you using?
We need more info. -
Could this be a monitor calibration issue? You PC monitor will differ from your TV.
Darryl -
Ive since discovered that on 2 different dvd players the problem exists, but 1 of my dvd players it plays fine as well as the computer dvd port. I'm beginning to think it may have something to do with it. It still is odd because the 2 that have the issue are different brands. I will try some additional players to see what that does. I usually save as a mpeg2 file then go back and render and burn some discs from the same project board. Still is an odd thing. Thanks for your help.
Red or Yellow?
By olyteddy in forum ComputerReplies: 4Last Post: 21st Nov 2010, 23:39 -
Red Flashes
By gerritv in forum Authoring (DVD)Replies: 1Last Post: 12th Nov 2009, 04:35 -
The RED Scarlet camera
By Wile_E in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 15Last Post: 25th Jul 2009, 01:47 -
Bright red, blue?? help...
By waefwaeefwaefw in forum EditingReplies: 3Last Post: 12th Sep 2008, 21:31 -
Borris RED
By xnowboardeveryday in forum EditingReplies: 1Last Post: 15th Oct 2007, 11:19
