I am trying to decide what video editing software I should purchase. I have tried a lot and have found Power Director & Ulead Video Studio the easiest software to use in regards to editing home video's adding Titles, Transitions and other effects. My problem is with the quality of the VCD I produce at the end of the whole process. The VCD when played on both my pc & my standalone VCD player is a little fuzzy and blocky. Before I started playing with editing software I read a lot of guides on this site about captureing and converting and decided to capture with VIRTUALDUB & HUFFY CODEC & use TMPGNE to convert. I have a TV capture card. The captured AVI (Pal VCD 352x288) look pretty good when preveiwed on the PC. Once converted using TMPGNE to mpg they still look pretty good when preveiwed on the PC. Once burnt using EasyVCD and then played on my standalone VCD player they don't look quite as good but still ok for VCD. But when I edit the captured avi in one of the above editing programs (worse in others I have Tried) & save as avi uncompressed then convert to mpg using tmpgne & burn with vcdeasy the play back quality is very poor. I have also tried to save the edited avi using the mpg convertions included in the editing software & the end resulte is the same.
Can anyone suggest a better way that might produce better results? Also, is one software better then the other out of the two I like?
Thanks.
Results 1 to 1 of 1
How do I lap dissolve with Cyberlink Power Director
By tonycopple in forum EditingReplies: 1Last Post: 27th Aug 2011, 19:05 -
Cyberlink Power Director does not recognize widescreen
By sektionschef in forum Video ConversionReplies: 4Last Post: 4th Aug 2009, 23:56 -
Cyberlink Power Director 7 - "Create" Function Problems!
By lapetite_66 in forum Newbie / General discussionsReplies: 4Last Post: 29th Jul 2009, 20:01 -
JVC HDD Camcorder/Cyberlink power director file import error
By lonewolf_mb in forum Newbie / General discussionsReplies: 7Last Post: 29th Dec 2008, 21:53 -
Cyberlink Power Director Problem
By ada1984 in forum EditingReplies: 6Last Post: 17th Nov 2007, 11:50
