Hello all,
I am attempting to convert several cassette tapes. I have my tape deck linked with RCA cables to my Canopus capture card, then linked via Firewire to my computer. I'm not sure which program to use to capture with. First of all, is my lineup correct?
Thank you
Theresa
Results 1 to 13 of 13
Sounds like it would work. I mean you normally capture audio and video; this would just be the audio. But why not just connect directly to your audio card? Then you could capture directly to wav and use much less disk space.
Darryl -
Thank you, Darryl. I'll try that For some reason, the programs I'm using- Premiere Elements 2.0 or WinDV - no signal is coming through. I'll switch over to audio card and try that.
Thanks for replying!
Theresa -
I always wished i had my ton of old cassette tapes so i could justify buying one of these to use.
http://cgi.ebay.com/Audio-Cassette-Tape-Converter-Adapter-to-iPod-MP3-CD-PC_W0QQitemZ2...d=p3286.c0.m14
Put it in an empty drive bay, just like a dvd rom/burner & slap in a casstte. -
I wish! Thanks for the link. Let me check the couch for lost change!!
I think I found the problem. The tape deck might be dead. When I play the tape, the light scale the displays the peak levels of the sound shows nothing. The tape is playing, but no sound is coming through. Lovely. Now I have to repair it.
Thanks to you all,
Theresa -
You can also use Total Recorder (not free). I like it because you just press 1 button to record to mp3 and you can see VU meter while recording and make level adjustments if needed. Total Recorder is the first program I ever got.
Thanks to you both! As soon as I know I have a working cassette deck, I'll post back with results. I already have Audacity but I'll look at Total Recorder also.
Theresa -
Originally Posted by jagabo
But i don't remember what program i used, that was many many moons ago, but i am sure it was free.
I think it was something that actually came with windows back then, maybe just the "sound recorder"
But i am sure there has to be some good free programs to capture directly in WAV from your sound card, regardless if you have onboard audio or a audio card.
It's just been a long time since i have had to do anything like that so i'm not up on it. -
Originally Posted by Theresa
But if the audio quality is good or if you're just in a hurry, MP3DirectCut can record directly to MP3, so no large wave files are created. Mp3DirectCut has some basic editing -- cut and paste, volume, fades, which it does on the encoded MP3, so no further conversion losses.
Also watch for ground loop hum, if everything is electrically grounded it should be minimised. Maybe connect an earth wire between the deck and PC. -
I converted about 300 cassette tapes to CDs.
I used Goldwave but Audacity or MusicMatch Jukebox will work.
I took the long route and recorded the whole tape and then edited the tracks. It was a lot more work than letting MMJB just record the tracks but MMJB has a habit of cutting one song into two or three tracks or combining two or three tracks because it can't differentiate the song breaks correctly.
Record as Wave files to create the CDs. If you want to store the music on your HDD and are worried about disk space then you can convert to high bitrate MP3. I would not record my music collection to 128 kbps MP3.
You should not need an amp since cassette players usually have built in amps (unlike turntables). Just hook the audio out from the cassette deck to the input of your sound card. Make sure you have Line In selected to record or you won't get any sound.
You'll want a cable like this...
http://www.newegg.com/Product/Product.aspx?Item=N82E16882123073
http://www.walmart.com/catalog/product.do?product_id=11684433
Tape decks are getting hard to find. Crutchfields has a Sony Dual Deck HX Pro for $150. -
just connect the tape deck directly to the line-in of your sound card. If you are not editing the sound or not thinking of putting it to CDs then use mp3directcut to record it to mp3 files. Otherwise use audacity to record and edit the sound before putting it to the CDs. All of these are freeware.
How Exactly Does Audio Capturing Work?
By Ownaholic in forum AudioReplies: 6Last Post: 16th Nov 2011, 08:18 -
Newbie : How to convert PAL into NTSC Format for Video Cassette Player
By kato2010 in forum Newbie / General discussionsReplies: 7Last Post: 11th Sep 2010, 10:40 -
How to convert 8mm video cassette to DVD
By greg555 in forum Newbie / General discussionsReplies: 1Last Post: 31st Jul 2007, 03:45 -
VHS cassette - when capturing to PC shows blue screens.
By 1gnition in forum Capturing and VCRReplies: 9Last Post: 23rd Jun 2007, 07:46 -
Best program to convert Audio Cassette Tape to WAV
By jimcornetet in forum AudioReplies: 8Last Post: 14th May 2007, 15:48
