i just encoded and .avi to dvd and the audio is out of sync!![]()
i always encode audio and video separately.
Does the audio and video have to be the exact same time!
EXAMPLE: video 1:20:50:58
and audio 1:20:50:58
or is it ok if the audio is a different time? im asking because the audio is always off by ms(milliseconds).
The audio on DVDs is often shifted relative to the video. For example, it may start a second later. In cases like that you can adjust the audio by adding a second of blank audio to the start, or using the audio skew ability of AVI files.
DVDs can also use variable frame rates. For example it may shift from 23.976 fps with pulldown flags to 29.97 fps interlaced. This can confuse some conversion programs.
ripped dvds when converted to avi out of sync
By angryassdrummer in forum Video ConversionReplies: 3Last Post: 9th Jan 2012, 07:43 -
Longevity of Standard DVDs and BluRay DVDs
By bmccollum in forum MediaReplies: 10Last Post: 20th Oct 2010, 19:32 -
Fixing / Determining Audio Sync Issues With Only Some DVDs
By TheNut in forum DVD RippingReplies: 5Last Post: 12th Dec 2009, 18:47 -
DVD Rom can burn DVDs but won't recognize burnt DVDs.
By soonie in forum DVD RippingReplies: 0Last Post: 23rd Aug 2009, 17:03 -
I want software that copies DVDs and transfers torrents to playable DVDs!
By maccaneer in forum MacReplies: 14Last Post: 28th May 2007, 10:02
