Hello again,
It's my second post on this board, I'm glad to meet you all.
I'm planning on buying a DVD recorder or HDD player/recorder but I've got a quick question...
Assuming we've got the same source (i.e analog TV signal), which one is better - a good TV tuner card or DVD recorder?
(by "better" I refer to the quality of the recorded video)
Thanks in advance!
Regards,
Lupo
A tuner card is better: you can use lossless compression while recording, then process the video the way you like. Very cheap modern cards (like Beholder at my location) give very stable results.
I prefer dvd recording,not much difference in picture quality when using best recording speed and no need to encode and no worries about audio sync,i used capture cards for years and wont use them again.
Originally Posted by Lupo
You get the best (i.e, cleanest and most easily post-processed and edited videos) by capturing to AVI or other workable PC format and rendering to DVD. But few have the time for all that work except for special projects and restorations. This assumes you'd capture with VDub or better software than the stuff supplied with most capture cards, stuff that's often untalented and user-UNfriendly, even when they work. If I had to choose between the quality from processing on a PC -vs- recording to an HDD recorder, I'd choose the PC. But if I had to choose between the quality of poor capture software -vs- recording to a decent DVD recorder, the recorder wins hands-down. The final decision, of course, is which would take up less of your time??? If time's the main issue (it usually is), go with the recorder.
HDD units are getting scarce. The few that are available today are no match for the good stuff of just a couple of years ago. If you're going to get an HDD, grab it soon. Factories are under great pressure to discontinue any product that lets you to make your own videos at home.
TV Tuner for Magnavox DVD Recorder
By gregmlr in forum Capturing and VCRReplies: 32Last Post: 26th Apr 2012, 22:07 -
Connect VCR/DVD Recorder to PC which has TV Tuner
By Butch1942 in forum Media Center PC / MediaCentersReplies: 1Last Post: 16th Feb 2009, 19:03 -
DVD Recorder/VCR With No Tuner - Link to Broken Tunered DVD Recorder
By Surfmaster in forum DVD & Blu-ray RecordersReplies: 1Last Post: 23rd Dec 2008, 02:05 -
tuner in DVD recorder
By miki100 in forum Newbie / General discussionsReplies: 7Last Post: 3rd Sep 2008, 23:18 -
DVD Recorder Tuner
By jh76 in forum DVD & Blu-ray RecordersReplies: 10Last Post: 7th May 2008, 13:24
