Since videowave4 comes up with errors all the way:
Is there any cool freeware prog that can capture DV via firewire, and that can split the file into scenes as well?
Hi, i've had my panasonic nv-ds38 for about a month, but am yet to use the firewire yet (lazy). I plan to use the firewire port of the audigy, so i jotted these addresses down, as i will need software, for when i get my act together:
http://www.scenalyzer.com/
(nearly free)
http://mcarr.eecs.umich.edu/dvio/
Good luck. -
The best freeware caps prog anyone can tell you would be.......
Morpheouse or winmx
get my drift
BTW..video vegas would be a good choice
stagAthlon xp-2400
60 gig.h/d.7200rpm
256mb ddr ram
Asrock:-k7s8xe.sis 748 chip set m/b
Win xp pro
Hollywood-dv bridge/Belkin firewire card -
An excellent little freeware program called DVIO is what you are looking for. The home page for it is at: http://mcarr.eecs.umich.edu/dvio/
Once you have the footage in DV format, you can use the free Scenalyzer program to get the separate scenes:
The amount of money the author charges for the full ScenalyzerLive program is a steal. Best $33 I've spent in a long time.
I've found the following page to be a good one for more information on various topics, ranging from DV to MPEG-2 encoder comparisons:
http://www.hlinke.de/Video-Links/video-links.html
Freeware to capture a shot from a video or DVD?
By gastrof in forum Newbie / General discussionsReplies: 7Last Post: 22nd Jul 2011, 04:11 -
which prog to capture ?
By hydra3333 in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 04:19 -
Capture device needed ...PLEASE!!!!! HELP!!!
By Bertomotology in forum Capturing and VCRReplies: 20Last Post: 4th Dec 2009, 16:29 -
Last Freeware Version of FastStone Capture Still Available
By Soopafresh in forum ComputerReplies: 6Last Post: 24th Apr 2009, 21:28 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 05:31
