I have a couple old workhorse desktops that are running XP.
It seems win7 requires full reinstallation on XP machines, and I was considering upgrading the mobo & CPU on one of them anyway. With a Vista laptop too, the Family Pack Upgrade looks like best bet.
I was wondering if it makes sense to upgrade the hardware (mobo & CPU) now under XP, so the machine would need a w7 upgrade instead of a full version.
But... what exactly is M$'s policy on XP reinstalls? Do they consider it the chip, or the board, or the OS's HD?
And would the timeframe be really short, or on into the demise of XP support?
(And, ditto this Q for Norton and any other machine-locked softwares.)
It's a combination of parts. CPU, motherboard, NIC, drives, RAM, graphics card, etc. Some number (6 I think, NIC counts as 2) can change within some period of time (6 months?) before it's considered a different computer. If your reinstall won't activate you can usually call MS and say your motherboard died and you had to replace it -- they'll usually accept that.Originally Posted by ahhaa
Need HDD upgrade advice for panasonic
By kennywally in forum DVD & Blu-ray RecordersReplies: 6Last Post: 7th Apr 2010, 12:49 -
Computer upgrade Advice...
By helper in forum ComputerReplies: 24Last Post: 31st Jul 2009, 13:13 -
Hardware advice, video card & monitor, DVI or VGA ??
By Noahtuck in forum ComputerReplies: 7Last Post: 12th Jul 2009, 01:58 -
Upgrade to HDTV advice
By stuntmaster in forum DVB / IPTVReplies: 4Last Post: 15th Oct 2008, 18:50 -
Software upgrade & Scanners for B&W negs?
By ahhaa in forum ComputerReplies: 2Last Post: 9th Jul 2007, 20:28
