Hi,
Im now very confused and dont know wich one I've to choose.
What is better in WinDV type 1 or type 2?
Some say type 2 is the way to go http://objectmix.com/adobe-premiere/234102-windv-questions.html
Others say there is no diffrence and you just have to convert it to type 2.
I´ve captured a VHS tape trough my camcorder but the audio goes out of sync, the more the video plays.
I´ve lost only 5 frames does that make this result? cause I think it more than that.
I dont need to transcode (maybe in the future) now I just always convert the DV-AVI files always with Vegas to MPEG2 without quality loss and burn that to a DVD.
Final question what is a sound click/pop? Has anyone a sample of that?
Wich one would you suggest? I've made a poll if you are sure could you also comment why it's better
	The flag once raised will never fall!
	Five dropped frames would result in a 1/5 second A/V desync, at worst. Your problem with A/V sync probably has nothing to do with the dropped frames reported by WinDV but rather loss of video sync inside the camcorder (from a bad sync signal on the VHS tape). You probably won't be able to fix that except by adjusting the video or audio length after capturing. The other option would be to get a full frame time base corrector but that will cost you about US$300.
 Regarding type 1 vs type 2 DV -- use whatever your software accepts. The only difference is type 2 contains a second copy of the audio track explicitly marked as audio in the AVI container. Both type 1 and type 2 have a copy of the audio track multiplexed in the video stream (but many programs can't access that copy).
	Back when the CPU was less powerful than today, Type 2 allowed edit programs to preview the timeline with less CPU activity. Type 2 was the default requirement but today most edit programs will accept and convert Type 1.
 Type 1 is about 6% more efficient for file copy transmission and storage.
 As Jagabo points out, your frames are being dropped during A/D processing before conversion to DV. This has nothing to do with Type 1 or 2 DV.Recommends: Kiva.org - Loans that change lives.
 http://www.kiva.org/about
	The video plays fine if do this in VirtualDub
 From under the "Video" dropdown menu, select "Framerate" -
 and select "Change so video and audio durations match"
 But how do I have to save the video in virtualDub with the same format DV-Avi? I did as Save old format avi with direct stream on both Audio and Video. But after I've saved I opened the video duration was 2 minutes and played slower.
 Maybe Im doing something wrong, what is the best way to save the video in VirtualDub?The flag once raised will never fall!
	Try the regular AVI export from VirtualDub. The old format can't handle over 4 GB.
	Is the audio now in perfect sync at all points in the video?
 That would suggest the problem was due to some uniform divergence between the two during capture.
 Would a bad sync signal on the VHS tape cause this, or would you expect that to be more variable in its effect?
	I used:
 S-video to Camcorder
 RCA to RCA joiner to RCA to 3,5mm jack.
 RCA joiner
 Maybe the audio gets slower/faster then the video cause of the use of 2 diffrent connectors.
 This solved it with (VirtualDub):
 Set under Video to Direct Stream copy and do this the same to audio.
 Save as AVI. The file size/quality will be the same but with the good audio.The flag once raised will never fall!
  Convert DV type 2 to type 1? Or is there an app that will correct sync?By Colmino in forum Newbie / General discussionsReplies: 7Last Post: 20th Dec 2022, 22:24
  How to convert a trp type file to Mpeg2 type?By Jemes-bs in forum Video ConversionReplies: 2Last Post: 13th Oct 2010, 16:59
  type 1 or type 2 capture-newbieBy sar in forum Capturing and VCRReplies: 6Last Post: 28th Jul 2008, 19:22
  DV AVI Type 2 -> Type 1 converter?By alx3d in forum EditingReplies: 3Last Post: 29th Dec 2007, 21:16
  Convert Type 2 DV to Type 1 (DVdate?)By nlec in forum Video ConversionReplies: 30Last Post: 30th May 2007, 14:52
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
