what colour could I print a 100 page document to use all inks equally?,,sorry I am not at all artistic, but end up always using black and the colours get old and clogged (bit like me)-thanks
PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS -
You pretty much can't, on most modern printers. On the old single-cartridge printers, they used a tri-color cart to make black (all colors mixed equally), but most new printers have multiple carts (4 or more), so you get true black.
It also depends on the document. If it is mostly pictures, it may use the colors equally. If mostly text, it will mostly use black.
You may want to look into a cheap monochrome laser printer. I got a Dell and HP for $65 and $120, respectively. For the occasional color print, I use my Epson inkjet (for home projects). -
You might try telling the printer that you are using photo paper instead of plain.
I have a Canon printer that uses a separate black pigment cart for text.
If I select 'photo', then the dye carts are used (black being generated from a composite of the colours). -
thanks for the help-appreciate it
Inkjet -vs- Thermal
By Nator in forum ComputerReplies: 5Last Post: 19th Mar 2012, 07:08 -
Ink cartridge cannot be reconized
By Teac23 in forum ComputerReplies: 2Last Post: 2nd Mar 2011, 11:04 -
Question about Ink Jet printableDVD's
By flyin-lowe in forum Authoring (DVD)Replies: 7Last Post: 23rd Nov 2010, 20:40 -
Pixma IP4000 ink in uk?
By franco in forum MediaReplies: 3Last Post: 30th Sep 2010, 18:13 -
HP printer ink...for sale
By Krispy Kritter in forum ComputerReplies: 1Last Post: 23rd May 2008, 07:30
