I want to be able to see long filenames of my Xvid and Divx files on my Philips DVD player and was wondering what the best settings are in ImgBurn? The app defaults to ISO9660+UDF and so I kept that, but don't know if Joliet needs to be there as well. On the Advanced/Restrictions tab there are numerous settings, with which I'm not too familiar, that deal with filelength restrictions. I tried Level X to get long names and while it appears to work for the player all spaces and punctuation show as underscores. I don't know if that is normal for the player or if there are better settings. Any help would be appreciated. Thanks.
EDIT: and I have updated the firmware to use long filenames (thanks, redwudz)
I wouldn't be surprised to see underscores to replace spaces in filenames, or probably with characters it doesn't recognize. And I assume you have changed the default firmware on the player to be able to display long filenames?
Ok, I did a little experimenting and the only thing one needs to do is add the Joliet label and select 1-64 chars method on the advanced tab. The Philips 5990/37 (with firmware upgrade for long filenames) will display nice long filenames:
S01E18_-_AND__THE__WHIMPER_IS____.AVI
becomes
S01E18 - And (The) Whimper Is!....avi
(I added extra punctuation to the above name when burning to see how the player would react)
I still left the ISO9660 and UDF defaults, but the player uses the Joliet when present. Nice!
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 02:07 -
How do make a DVD video disc with an .avi file with ImgBurn?
By DaneClark in forum Authoring (DVD)Replies: 4Last Post: 3rd Jul 2010, 02:08 -
I have an Aopen Dvd Burner, how can I set booktype in imgburn?
By frieday in forum Authoring (DVD)Replies: 13Last Post: 3rd Nov 2009, 05:30 -
S2D have its own settings when using imgburn ?
By IPBR21054 in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 20th Aug 2009, 17:36 -
Can DVDShrink be set to use ImgBurn for burning?
By RoyGBiv-inRI in forum DVD RippingReplies: 7Last Post: 21st Jul 2007, 13:17
