hello
i have the same problem with premiere 6, always have those cracking noises when i play a mpg, i hope someone here knows how to fix that
hey me again, last week I posted here because of that noise problem in premiere 6. I got an answer and since you didn't I just give you a copy of the posting:
ummm, try this it might work
load the video
do you see where the audio track is....
to the left there is a box to expand the audio (to see the wave pattern)
expand the track
now if you click on the wave (it should place a red dot)
and create a line and click again on the other end of the audio ( go from left to right )
what I am really trying to tell you is you can lower the volume on the audio, it sounds like a hard thing to do when you can just turn it down so to speak, but what you are really doing is cutting off some of the peaks and hopefully the noise your getting is in the higher peaks (the ones you cut off )
if you need more help feel free to email me
title it "prem6 help"
_________________
FenDers
"Hail to the King, Baby" -
thank you
unfortunatly that didn't do the trick for me. But say, does your mpeg files play back really choppy in premeire? like the video skips? cause mine does, not avi files though. the video skipping isn't such a big deal because it would play smooth on the exported file, but the ticking audio wouldn't go away.
Speaking of which, I noticed that the ticks occure at each second, not all of them are real noticable but all the ones that are noticeable are right on a second mark. Anyways food for thought.
Thanks though
Mongoo -
I do not unfortuantly have Premiere 6, but with regards to the ticking audio. Is there an option called "Pad for CDROM".
If there is, and it is ticked, CLEAR IT.
Canon DC230 New Ticking Sound On Playback
By cool4cats in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 7th Jan 2012, 07:23 -
DubIt Audio Editor - Adding sounds to Video Files
By devilcoelhodog in forum Newbie / General discussionsReplies: 0Last Post: 27th Sep 2011, 16:54 -
strange sounds in audio exported from premiere pro cs3
By codemaster in forum EditingReplies: 0Last Post: 25th Jan 2011, 18:57 -
Correct settings for MPEG-4 AVC/H.264 for Premiere Pro 1.0 (Premiere 7.0)
By urpq32 in forum EditingReplies: 2Last Post: 24th May 2010, 04:22 -
Mpeg-4 to mpeg-2 for mac/adobe premiere pro......
By macbookuser in forum Newbie / General discussionsReplies: 1Last Post: 4th Sep 2007, 21:48
