    Aug 2009
    Hello,
    I think I may be having some issues with WMP swapping codecs to play videos at different times.
    Sometimes I play an interlaced video and it plays deinterlaced, sometimes the same video doesn't,
    and it's irritating me. I'd like to go through and clean up all of the old/useless/conflicting
    codecs that I have on my system. According to Windows Media Player, I have the following list of
    codecs installed. GSpot gives me a whole different list. Could someone give me some advice on
    how to go about eliminating the old ones I don't need? Some of these are linked with programs
    I don't even have anymore, like ULead and the ancient Attila MPEG decoder. Honestly, for a lot
    of these, I don't even know if they are used for anything.
    Audio Codecs
    Type Name Format Binary Version
    ACM Microsoft IMA ADPCM CODEC 0011 imaadp32.acm 5.1.2600.5512
    ACM Microsoft ADPCM CODEC 0002 msadp32.acm 5.1.2600.5512
    ACM Microsoft CCITT G.711 A-Law and u-Law CODEC 0007 msg711.acm 5.1.2600.0
    ACM Microsoft GSM 6.10 Audio CODEC 0031 msgsm32.acm 5.1.2600.0
    ACM DSP Group TrueSpeech(TM) Software CODEC 0022 tssoft32.acm 1.1.1.5
    ACM Microsoft G.723.1 CODEC 0042 msg723.acm 4.4.0.3400
    ACM Windows Media Audio 0161 msaud32.acm 8.0.0.4487
    ACM Sipro Lab Telecom ACELP.net audio codec 0130 sl_anet.acm 3.2.0.0
    ACM Fraunhofer IIS MPEG Layer-3 Codec (advanced) 0055 ivimp3en.acm 4.0.0.0
    ACM Indeo® audio software 0402 iac25_32.ax 2.0.5.53
    ACM Intervideo MP3 Audio CODEC 0055 ivimp3en.acm 4.0.0.0
    ACM Microsoft PCM Converter 0001
    DMO InterVideo G726Dec DMO 0045 G726Dec.dll 1.0.0.1
    DMO WMAudio Decoder DMO 0160, 0161, 0162, 0163 wmadmod.dll 11.0.5721.5145
    DMO WMAPro over S/PDIF DMO 0162 wmadmod.dll 11.0.5721.5145
    DMO WMA Voice Decoder DMO 000A, 000B wmspdmod.dll 11.0.5721.5145
    Video Codecs
    ICM Cinepak Codec by Radius cvid iccvid.dll 1.10.0.12
    ICM Logitech Video (I420) i420 lvcodec2.dll 10.0.0.1438
    ICM Intel Indeo(R) Video R3.2 IV32 ir32_32.dll 3.24.15.3
    ICM Intel IYUV codec IYUV iyuv_32.dll 5.1.2600.5512
    ICM Microsoft RLE MRLE msrle32.dll 5.1.2600.5512
    ICM Microsoft Video 1 MSVC msvidc32.dll 5.1.2600.0
    ICM Microsoft YUV UYVY msyuv.dll 5.3.2600.5512
    ICM Toshiba YUV Codec Y411 tsbyuv.dll 5.1.2600.0
    ICM Microsoft H.263 Video Codec M263 msh263.drv 5.1.2600.5512
    ICM Microsoft H.261 Video Codec M261 msh261.drv 5.1.2600.5512
    ICM Intel Indeo® Video 4.5 IV41 ir41_32.ax 4.51.16.3
    ICM Indeo® video 5.10 IV50 ir50_32.dll 5.2562.15.55
    ICM Canopus DV CDVC cdvccodc.dll 2.1.0.1
    ICM DVCPRO HD CDVH cdvhcodc.dll 2.0.0.4
    ICM Canopus HQ CUVC cuvccodc.dll 1.4.0.4
    ICM Canopus Lossless CLLC cllccodc.dll 1.2.0.2
    ICM DVCPRO50 CDV5 cdv5codc.dll 2.0.0.3
    ICM DivX® 6.8.4 Codec (1 Logical CPU) divx DivX.dll 6.8.4.1
    ICM DivX® 6.8.4 YV12 Decoder yv12 DivX.dll 6.8.4.1
    DMO WMVideo Advanced Decoder DMO WMVA, WVP2 wmvadvd.dll 11.0.5721.5145
    DMO Mpeg4s Decoder DMO mp4s, MP4S, m4s2, M4S2 MP4SDECD.dll 11.0.5721.5145
    DMO WMV Screen decoder DMO MSS1, MSS2 WMVSDECD.dll 11.0.5721.5145
    DMO WMVideo Decoder DMO WMV1, WMV2, WMV3, WMVA, WVC1, WMVR, WMVP, WVP2 WMVDECOD.dll 11.0.5721.5145
    DMO Mpeg43 Decoder DMO mp43, MP43 MP43DECD.dll 11.0.5721.5145
    DMO Mpeg4 Decoder DMO MPG4, mpg4, mp42, MP42 MPG4DECD.dll 11.0.5721.5145
    MPEG/DVD Filters
    Type Name Binary Version
    video InterVideo Video Decoder IVIVIDEO.ax 6.0.6.42
    video "MainConcept (Adobe2) MPEG Video Decoder"
    video Ulead MPEG Video Decoder
    video Attila MPEG Video Decoder mpgvideo.ax 1.0.0.5
    audio InterVideo Audio Decoder iviaudio.ax 6.0.6.42
    audio "MainConcept (Adobe2) MPEG Audio Decoder"
    audio Ulead MPEG Audio Decoder
    audio Attila MPEG Audio Decoder mpgaudio.ax 1.0.0.2
    audio Ulead AC3 Audio Decoder 2
  2. Rendering the file in graphstudio will tell you what current directshow filter chain is in use
    You change the merit, unregister, or register other filters withing graphstudio or using radlight filter manager
    ACM type or VFW type codecs are not used by WMP (WMP is a directshow player), but you can manage them with vcswap
    I'm guessing you probably had a "codec pack" installed at one point...
    Aug 2009
    I can do this with GSpot as well right? I was a little uncertain about the terminology, unregister means to remove, uninstall or delete? Is there a way to remove and delete them while knowing which decoders are necessary and which aren't? Also, I'm a little unsure about the filter type and what they mean exactly, for example, ICM and DMO.
    It's very likely that when I first got this computer back in 2004 that I installed a codec pack. Ugh.
