  1. Member leghorn's Avatar
    Apr 2007
    Germany
    I have a video encoded with a resolution of 512x384 (4:3). When I watch it in MPC with default settings on, it appears stretched from top to bottom. So I have to set the aspect ratio to 16:9 manually. Looks fine then.
    Now, I'd like to convert that movie to DVD using FAVC. And I want it to show in 16:9. There's a way to do that in C2XDVD. Anyhow, I use FAVC. So, is there a switch (like in MPC) to accomplish that?
    Can't you set the aspect ratio under dvd options in FAVC(was a long time I ?
    Or else change the aspect ratio in the avi using mpeg4 modifier and see if favc reads it. If mp4 use yamb or mkv mkvtoolnix to set aspect ratio.
  3. Member leghorn's Avatar
    Apr 2007
    Germany
    mpeg4 modifier looks promising. i'll give it a try...
    Das Leben ist eine Nebelwand voller Rasierklingen. (C. Bukowski)
    Apr 2004
    Miskatonic U
    I believe to do this in favc you need to use FitCD to create an Avisynth script that will correctly resize and pillarbox your video for 16:9 output, run it through FAVC, then use IFOEdit/PGCEdit to alter the DAR to 16:9 in the IFO files.
    Read my blog here.
  5. Member leghorn's Avatar
    Apr 2007
    Germany
    mpeg4 mod wouldn't work. maybe fitcd can do it. if eventually nothing else works, maybe the tv has an 4:3 / 16:9 switch to make it look right...
  6. Member MysticE's Avatar
    Nov 2003
    Try this handy little app on your finished DVD.
    http://www.softpedia.com/get/CD-DVD-Tools/Data-CD-DVD-Burning/Simple-DVD-Creator.shtml
    Load up your IFO, then under video set it at 16:9. It may look like it's stalled some times, just let it finish. Great for demultiplexing VOBs and creating DVDs from random VOBs also.
  7. Member leghorn's Avatar
    Apr 2007
    Germany
    I've found a solution: I've converted the avi to DVD with FAVC. Since that gave a 4:3 output I changed the AR settings with PgcEdit. Now it looks 16:9 and everything's fine
    Thanks for your efforts to help!
