ok heres it in a nut shell, i converted a mkv file to mpg so that i could play it on my ps3, its just slightly bigger then a dvdr and i want to turn it into a avchd (that will fit a dvd-r)
now if i google mpg to avchd all i find is avchd to mpg lol so any help is apreciated, i have ubuntu and windows 7 not sure if that helps
i set the video codec to h.264 but output formats can only be (mkv file, mp4 file,m4v file,avi file or ogm file) no mention of avchd, am i missing something?
you need to author it, eg. multiavchd or tsmuxer
they will re-wrap it into the transport stream .m2ts , and create the necessary support files & folders for the avchd structure
if your mkv was within spec, you could just use multiavchd on that, and save hours, and lose no quality
overhead for transport stream is ~5-7% larger than mkv container. So if your mkv is bordering on the dvd5 limit, you will have to re-encode or cut sections out -
Pick MKV. You can feed the output to tsmuxer or MultiAVCHD.Originally Posted by mrgreaper
avchd is h264. same thing different name.
AVCHD is a format for recording and playback of high definition video. Video is compressed in MPEG-4 AVC/H.264 format, and audio is recorded in Dolby Digital.
how can i down convert avchd
By jamminj2b in forum Newbie / General discussionsReplies: 7Last Post: 1st Jan 2012, 19:19 -
Convert MPG (720p) to AVCHD for Panasonic Blu-ray players...
By hiimbored in forum Video ConversionReplies: 0Last Post: 2nd Jul 2011, 23:52 -
software to batch convert m2ts format avchd to mts avchd?
By masterpug in forum Video ConversionReplies: 0Last Post: 14th Aug 2010, 02:06 -
Convert AVCHD
By mkrve in forum Video ConversionReplies: 36Last Post: 7th May 2010, 03:39 -
AVCHD (MPG) to MP4
By Cazz in forum Video ConversionReplies: 4Last Post: 19th Apr 2008, 11:58
