hi there
i am unable to play this file in any players(vlc,wmp, wmp classic, quicktime, gom) i have kazza mega codec pack. i want to convert this file to mpeg
it says Codec Status Undetermined in gspot
in mediainfo
General
Complete name : E:\Cam_03\2009-07-26\15-10-36.mp4
Format : MPEG-4 Visual
File size : 2.24 MiB
Video
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default
Width : 320 pixels
Height : 240 pixels
Display aspect ratio : 4/3
Resolution : 24 bits
Scan type : Progressive
can someone please help me on converting this file.
Results 1 to 10 of 10
What camera (or a phone?) was used to create the video? It could be one of those odd camera MPEG4 formats that other programs might have problems with, but it does seem a little odd that VLC wouldn't be able to play it.
Another thing that seems odd to me is that the video's only 2.24 MB, even for a 320x240x24 video.
If cameras add ten pounds, why would people want to eat them? -
I have the same problem with the following file:
Formato : MPEG-4 Visual
Dimensione : 1,32 GiB
Video
Impostazioni del formato, BVOP : No
Impostazioni del formato, QPel : No
Impostazioni del formato, GMC : No warppoints
Impostazioni del formato, Matrix : Default (H.263)
Larghezza : 720 pixel
Altezza : 304 pixel
AspectRatio : 2,35:1
ColorSpace : YUV
ChromaSubsampling : 4:2:0
BitDepth/String : 8 bits
Tipo di scansione : Progressivo
Compressore : DivX 5.2.1 Beta (UTC 2004-09-08)
What kind of extension must be used with this kind of file and, what should I do to see and convert it? WinFF said "Unknown Format".Last edited by Puppybarf; 4th Jul 2010 at 04:16. Reason: Info added
WinXP SP3-ASUS P5K-Intel Core2 Quad Q6600-Kingston DDR2-800 4GB-Maxtor STM3320613AS-LG GSA-H42N-PHILIPS SPD6002T-Gainward 9500GT-Pinnacle 700-PCI-Realtek HD -
Well, that's basically a DivX-encoded AVI, but it's odd that WinFF wouldn't know what to do with it... unless there's something odd about the filename (extra spaces, symbols it can't recognize, etc.) Does the filename have the extension .avi?
Try copying the file, and renaming the copy "movie.avi". Then, see if WinFF has a problem recognizing what to do with it.If cameras add ten pounds, why would people want to eat them? -
Nothing to do... it's Unknown Format again
You might try a different converter, like XMedia Recode, for example. WinFF unfortunately hasn't been updated in a while, and the versions of ffmpeg and any other encoder it uses might not be able to handle your video as well as newer versions (XMedia uses ffmpeg as well).
If you're not set on using an ffmpeg-based encoder, there are other choices as well. I'm still not sure, offhand, why WinFF would have problems with the video, though.If cameras add ten pounds, why would people want to eat them?
How to convert to MS MPEG-4 Visual ?
By andy3 in forum Video ConversionReplies: 0Last Post: 22nd Jul 2011, 05:36 -
ffmpeg and mpeg-4 visual simple profile level 3 (packed bitstream)
By Witchking in forum LinuxReplies: 2Last Post: 6th Oct 2009, 13:08 -
visual basic code
By kudoshinichi in forum ProgrammingReplies: 1Last Post: 21st Jan 2009, 08:30 -
mpeg 2 visual / eyes
By 45tripp in forum Newbie / General discussionsReplies: 3Last Post: 20th Jul 2008, 09:14 -
Audio but no visual with ES35v
By Bealey in forum Newbie / General discussionsReplies: 0Last Post: 9th Jul 2008, 04:01
