When you play a SD DVD on a Blueray player does it use the blue laser or do they have red laser for SD DVD?
I would suspect it has to have a red laser. Isn't the blue laser finer than a red? I don't know if it could widen its focus for the bigger pits on a dvd.
Or am I misinterpretting the way the laser works?Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Well, I believe DVD players already usually have two different lasers - one for CDs, the other for DVDs - so it wouldn't surprise me if Blu-Ray players contained all three lasers. And, it wouldn't surprise me if that tended to drive up the price a bit, either.
If cameras add ten pounds, why would people want to eat them? -
Here's a side question:
Didn't hddvd use the standard dvd laser? Wasn't it something about the way the hddvd was produced that allowed the extra data without the need for a different laser?
Or am I misremebering that? Because wasn't the hddvd suppsed to be cheaper to produce than bluray? And wasn't the production of the actual disc supposed to use most of the dvd methods and not need to be retooled like bluray does?Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
HD-DVD were indeed pressed on standard DVD presses,not needing the specialized presses for Blueray.
Sorry, but your memory is faulty. HD DVD used the blue laser that BluRay also uses. You are right in remembering that the discs were able to be produced on DVD production lines, but I never saw any explanation as to why that was. The discs themselves have much smaller pits than red lasers can read and thus required the use of blue laser.Originally Posted by yoda313
Roku Vs. Blueray player
By RustyBob in forum Video Streaming DownloadingReplies: 1Last Post: 24th Jan 2011, 13:02 -
BlueRay Rips work on normal DVD player NTSC?
By Reesche in forum MacReplies: 5Last Post: 2nd Aug 2009, 05:27 -
no audio when played in DVD player? help
By cpeters12 in forum Authoring (DVD)Replies: 2Last Post: 29th Jul 2009, 17:01 -
Why do HD dvd play chopping using computer versus smooth on blueray player
By CX7 in forum Newbie / General discussionsReplies: 10Last Post: 6th Nov 2008, 18:23 -
no audio when played on dvd player
By soccer in forum AudioReplies: 6Last Post: 4th Aug 2007, 19:18
