Results 1 to 13 of 13
  1. I need a codec to view the 720p mp4 clips from my cyber-shot camera. I installed the software it came with but it didn't seem to install the codec.
    It's a Sony W290 camera.
  2. Use mediainfo to determine which codec
    or
    Just use vlc or kmplayer to play, they include most of the major splitters/decoders
  3. General
    Complete name : M4H00099.MP4
    Format : MPEG-4
    Format profile : Sony PSP
    Codec ID : MSNV
    File size : 20.5 MiB
    Duration : 19s 519ms
    Overall bit rate : 8 795 Kbps
    Encoded date : UTC 2009-12-09 01:18:05
    Tagged date : UTC 2009-12-09 01:18:24
    Video
    Format : MPEG-4 Visual
    Format profile : AdvancedCodingEfficiency@L4
    Format settings, BVOP : Yes
    Format settings, QPel : No
    Format settings, GMC : No warppoints
    Format settings, Matrix : Default (H.263)
    Codec ID : 20
    Bit rate mode : Variable
    Bit rate : 8 728 Kbps
    Nominal bit rate : 9 000 Kbps
    Maximum bit rate : 14.0 Mbps
    Width : 1 280 pixels
    Height : 720 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 29.970 fps
    Resolution : 24 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.316
    Stream size : 20.3 MiB (99%)
    Audio
    Format : AAC
    Format version : Version 4
    Format profile : LC
    Format settings, SBR : Yes
    Format settings, PS : Yes
    Codec ID : 40
    Duration : 19s 498ms
    Bit rate mode : Constant
    Bit rate : 64.0 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Resolution : 16 bits
    Stream size : 153 KiB (1%)
    What codec do I download to be able to view the video file with windows media player?
  4. ffdshow for the decoder
    http://sourceforge.net/projects/ffdshow-tryout/files/
    you may need a mp4 source filter/splitter if you don't already have one, just download the one from the following, and register the .ax with radlight filter manager
    http://sourceforge.net/projects/guliverkli2/files/DirectShow%20Filters/
  5. I downloaded ffdshow, MP4Splitter.ax, and Radlight filter.
    I clicked the register button in Radlight, selected MP4Splitter.ax, and I get an error message: DllRegisterServer failed in C:\Users\User\Documents\MP4Splitter.ax with error code : 0x80070005
  6. Are you logged in as administrator or have admin priviledges?
    A quick search on Google suggests that error code has to do with access restrictions
    Or maybe it's your security/OS firewall settings ?
  7. I'm logged in as admin and never had any problems installing anything else. What could I be doing wrong?
  8. Not sure, I just tried that exact procedure and it works here
    You used the one dated MP4Splitter_20081210.zip?
    Try registering in from a different folder, like the desktop (just grapsing at straws here, it shouldn't matter)
    You still have to option to use another player e.g. mpchc, vlc, kmplayer
    Mar 2009
    europe
    you can try: Splash or VLC.
    i remember that i used Splash with sony t500 clips and worked fine.
    i has its own audio/video codecs and supports dxva.
  10. All still cameras use MPEG-4 so install Quicktime or Quicktime Alternative.
    Mar 2009
    europe
    quicktime? i dont know quicktime pro but quicktime is one of the worst players i ever tried
  12. Originally Posted by nitro1973
    i believe he is just suggesting you install it because it will install a mp4 codec, not to use the player.
    Mar 2009
    europe
    true, i didnt think about it.
    but its still not the best solution
    i would prefer splash or ffdshow instead.
