    Dec 2006
    Ive just installed VirtualDub but when I try to open Avi file it says it needs Video for Windows compatable codec to decompress video.Could someone tell me how I do this.Many thanks
  2. You need a VFW decompression codec for the type of video used in the AVI file. Use GSpot or MediaInfo to see what codec is required.
    Jul 2009
    Spain
    Whatever codec it is, it is likely that ffdshow provides it, so install ffdshow if you haven't already.
    Then use its VfW video decoder configuration to 'switch on' the codec required.
    Dec 2006
    Many thanks for the reply
    Dec 2006
    The Output Video is not the same ratio as the input video.Any further help apprecciated
  6. Select a compression codec and configure it: Video -> Compression...
