    Aug 2006
    Australia
    I used to be able to hover over my avi files and a pop up would tell me the length of the file - it doesn't do that now - it just shows the type and size.
    I also have my movies folder (and sub folders) set up with columns named Duration, Dimensions etc but there's no info in them - there used to be a week or so ago - only just noticed these problems today so not sure when they stopped working.
    How do I get these things to work again.
    The only playing I've done with my PC lately was to update codecs and disable some shell extensions because I was having trouble activating avi files in Windows Explorer when I double clicked on it (WE kept crashing when I double clicked on an avi). I've checked the shell extensions I disabled but none of them seem to have anything to do with this problem.
    TIA
    Olly
  2. Originally Posted by OllyPomm
    That's why you no longer get the running time. The codecs and shell extensions are where that information comes from. Try a System Restore to back before you updated codecs.
  3. Member Safesurfer's Avatar
    Mar 2004
    To reenable Media preview in Windows Explorer you can type
    Start>Run>regsvr32 shmedia.dll
    If you have any buggy codecs, you may get the crashing/freezing problem again.
    You could also use an app such as Mediainfo to get the same info and more.
    "Just another sheep boy, duck call, swan
    song, idiot son of donkey kong - Julian Cope"
  4. Let me guess... K-Lite?
    Aug 2006
    Australia
    No, I downloaded and installed Xvid, Divxinstaller, Codes6030allin1 & shexview
    I've had K-Lite for ages and it's never given me any problems.
    Olly
    Aug 2006
    Australia
    Start>Run>regsvr32 shmedia.dll worked!!!
    Also downloaded Mediainfo which will come in handy. THANKS!!!
    Olly
