Hey all,
Since I am not sure where my problem is arising I couldn't put this in a more specific forum. My friends have been trying to capture XBOX gameplay without buying an expensive capture card. A Dazzle DVC-80 I had worked with Windows XP, but was dropping frames (Due to USB 1.0 I presume?). We then tried relaying the gameplay through my Sony RDR-VX530 DVD/VHS combo, recording onto Memorex (yea, I know they suck) DVD+R discs. Finalizing them was surprisingly quick and I was disappointed to find they did not run on either a Mac or a PC, each having capable drives. The DVD came up as black, though Device Manager showed 4.4 gigs out of 4.7 and the other specifications. Is there a way to still extract these files on Mac or PC? What filetype does Sony DVD burners record to (Not in manual)?
Oh..DVDs play in the RDR-VX530 (of course).
Thanks in advance for any help, sorry if its a common issue or if relevant details are lacking.
Disc info viewed from Mac:
Disk Identifier : disk1
Media Name : MATSHITA DVD-R UJ-845E Media
Media Type : DVDROM
Connection Bus : ATA
Connection Type : Internal
Connection ID : Device 0
Device Tree : mac-io/ata-3@20000/@0:0
Locked : Yes
Writable : No
Ejectable : Yes
Mac OS 9 Drivers Installed : No
DVDROM : Yes
Optical Media Type : DVD+R
Device Type : CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-RW, DVD+R, DVD+RW
Total Capacity : 4.4 GB (4,700,372,992 Bytes)
S.M.A.R.T. Status : Not Supported
Disk Number : 1
Partition Number : 0
Results 1 to 1 of 1
Sony dvd recorder model RDR-GX300 cannot play/record discs
By hdubya in forum DVD & Blu-ray RecordersReplies: 1Last Post: 26th Aug 2011, 03:40 -
unable to see DVD's burned on my computer on the new Blue ray player.
By kindrob in forum Newbie / General discussionsReplies: 26Last Post: 8th Dec 2010, 02:49 -
Burned DVDs on DVR, finalized, & now SOME of them will not play on that DVR
By justkay in forum DVD & Blu-ray RecordersReplies: 21Last Post: 24th May 2010, 12:44 -
Burned DVD from TV and won't play in computer
By dnlowe in forum DVD & Blu-ray RecordersReplies: 4Last Post: 12th Sep 2009, 18:41 -
Sony RDR-VX530
By tvlreject in forum DVD & Blu-ray RecordersReplies: 1Last Post: 5th Mar 2008, 21:40
