I prefer to use a built in windows software over 3rd party apps. How this can be done using window 7 apps? Since I got my windows 7 I got a bunch of WTV files and I cannot simply copy them to a shared drive on my network and watch them using my non windows 7 (xp) laptop. I know I can convert each one file at a time from windows 7 but I don't know how to convert the entire folder at one time.
Results 31 to 40 of 40
I use RemuxTool with a batch file. RemuxTool comes from - http://experts.windows.com/frms/windows_entertainment_and_connected_home/f/49/t/95712.aspx
My batch file looks like this:
for %%i in ("*.wtv") do call :LOOP "%%i"
GOTO:EOF
:LOOP
if not exist "%~n1.mpg" C:\PROGRA~2\Java\jre6\bin\java.exe -cp %~dp0\remuxTool.jar util.WtvToMpeg -i %1 -o "%~n1.mpg"
if errorlevel 1 GOTO:EOF
del %1 -
I am using CONVERTWTV and it works for me now. However I prefer not using 3rd party apps and cjbrown80 stated it was possible to do so with Windows 7 "without using a piece of software" or did I misunderstand him? I was hoping that it was built into windows 7 to do batch convert WTV to other format so I can watch them using XP.
Just click on the right button on your mouse ... on the WTV video file ... a menu will drop down and this will allow you to convert a wtv video to a ... DVR-MS ... video file.
This a Windows 7 built in feature.
Batch encoding is NOT one of the features ... Windows 7 has included ... that I know of. -
I was doing the right click and convert to DVRMS but I have lots of recorded media that I like to convert to use on my older windows. Now I am just using convertwtv and it works for me. It was just $0.99 so it did not break my bank and it works.
Actually batch encoding is a built in feature. I found this forum on technet that mentions an executable that is included in the windows/ehome directory called WTVConverter.exe that can batch convert entire directories of WTV files.
http://social.technet.microsoft.com/Forums/en/w7itpromedia/thread/f1b87068-6ba0-4d68-8...8-13d57497adb6
Also mentioned is a script that will run in your system tray and automatically convert new WTV files as they are recorded.
http://wtvwatcher.codeplex.com/
I hope this helps. I joined just to post it. -
It's now June 25, 2012 ... any new stuff or updates on the best way to convert DVR-MS (best quality) to 720p/1080p H.264 and IMPROVE the quality? Yes, we'd also like to edit out commercials.
We are playing with the latest VideoReDo "H.264" beta but no conclusion yet.
$100 seems a bit steep ... anything else out there?
Thx,
Scott -
since dvr-ms is basically mpeg-2 why not simply:
(0. remux dvr-ms to mpg with ffmpeg in case ProjectX doesn't support dvr-ms)
1. run dvr-ms through ProjectX to a. fix problems in stream, b. extract audio and video streams
2. run extracted raw streams through Cuttermaran to cut out commercials (and create mpeg output)
3. reencode and filter video with your favorite encoding tools that supports Avisynth and x264
btw. depending on your quality messure you will probably not improve quality, since you are reencoding into a lossy format (assuming you are not using H.264s lossless profile, which would blow up the file size),... depending on the source you can boost quality by doing filtering, but objectively you can only keep or loose quality through reencoding.
Cu Selur -
VideoReDo TV Suite H.264 is the best product available for what you want to do. It is probably worth the $100. If you happen to live in N. America, I have not heard of anything else that is as good as VideoReDo's product line for dealing with the transmission errors that are so common in recorded ATSC/QAM streams.
MCEBuddy and MC-TV Converter have an auto-conversion feature. I have not used the feature and cannot comment on its performance, but it appears that you can set these programs to run at a specified time to convert files in the specified folder to MP4 HQ, and remove commercials with Comskip. Both are fine for simply converting from .DVR-MS or .WTV to .TS, but it is likely that neither handles transmission errors gracefully when converting to H.264 or removing commercials.
Ripping Music Videos From WTV - DVR-MS - MPEG?
By skywalka in forum EditingReplies: 5Last Post: 12th Jan 2011, 02:13 -
WTV/DVR-MS files into usable MPEG format?
By CursedLemon in forum Newbie / General discussionsReplies: 6Last Post: 24th Jul 2010, 09:21 -
Low Cost (Read:Free) Options for DVR-MS/WTV Files
By dj4monie in forum Video ConversionReplies: 4Last Post: 28th Mar 2010, 18:32 -
Convert .wtv to .dvr-ms and lost audio?
By greyfalcon in forum DVB / IPTVReplies: 0Last Post: 24th Mar 2010, 03:53 -
Converting WTV/DVR-MS to edit in Windows Movie Maker
By abw1987 in forum Newbie / General discussionsReplies: 8Last Post: 23rd Sep 2009, 05:58
