I have spent a gread deal of hours trying to figure out a conversion tool and using the correct parameters to encode a TV recording so that I do not get sync issues.
I record TV shows using Windows Media Center and a Pinnacle analog TV USB stick.
The resulting dvr-ms is in sync and looks good. But when I try to convert it to something smaller the audio goes out of sync. This it probably due to a crappy recording. It happens in all recordings though.
I have posted a test recording so I dare someone to try and convert it with the audio in sync.
I use a command line conversion tool as I want the conversion to be scheduled. I use mencoder but I can use any other conversion tool.
I prefear encoding in Mpeg4 AVS and AVI or MP4 container but this is not the issue here as ALL types of my conversions are out of sync.
I also prefer 480x320, 640x480 format or original.
Go ahead and try converting my test file.
http://www.gigasize.com/get.php?d=gxmny6vlvtc
If you succed in converting this recording and there is no sync please post mencoder command!
_______________
Results 1 to 1 of 1
Out of sync issues after encoding and muxing?
By mrjust in forum Newbie / General discussionsReplies: 3Last Post: 27th Mar 2010, 17:06 -
Higher bitrate encoding causes audio sync issues
By keiron in forum Video ConversionReplies: 3Last Post: 12th Jun 2008, 04:37 -
I am Legend Encoding (Blu-ray) audio sync issues
By Ansuer in forum Blu-ray RippingReplies: 21Last Post: 1st May 2008, 17:54 -
mini dv analog recording pass
By nivek_nayr in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 15th Feb 2008, 20:42 -
Sync issues with encoding for DVD or Web
By sfischer in forum MacReplies: 2Last Post: 26th Dec 2007, 19:01
