I noticed that one of the buttons in my DVD title menu doesn't work. It's the one that plays whole the movie. All the other buttons that are responsible for playing chapters work just fine. I tried googling that but all I get is about buttons of DVD players.
Can this be fixed not affecting the other buttons?
yaro
I would try fix the dvd using pgcedit (click on for some guides) or dvdremake pro.
The guide was for disabling a button and so I thought the opposite will enable it but not. It got even more complicated as I figured out that the button actually works but it effectively reloads the menu instead of playing the whole movie. When I imported the movie to DVDRemake Pro and pressed Debug and then presed the button the last command was "Reload". I'm not much familiar with DVDRemake so I had trouble getting out from that Debug screen and in the end had to close the program from Task Manager.
yaro -
Still no clues? If only I knew what command I am supposed to see when activation that button maybe that could help?
yaro
Extracting menu buttons
By headless chicken in forum MacReplies: 0Last Post: 2nd Apr 2012, 23:54 -
Can title menu have active multiple thumbnails using CXtoD (using 1 title)?
By bobbyg in forum Authoring (DVD)Replies: 1Last Post: 26th May 2010, 09:32 -
Proplem with mapping menu and title buttons using DVDit PRO 6
By jakewoodblues in forum Authoring (DVD)Replies: 0Last Post: 14th Apr 2010, 16:56 -
Motion Menu Buttons
By lapetite_66 in forum Authoring (DVD)Replies: 5Last Post: 29th Jul 2009, 15:45 -
Menu with image buttons
By lex1972 in forum Authoring (DVD)Replies: 5Last Post: 24th Nov 2007, 07:02
