  1. I recently moved my audio receiver from one shelf to another. When I hooked everything back up I noticed that the sound was a bit off. I checked the speaker wires and everything was working fine. When the audio became very echoing (like I was listening to it in a museum) I started fumbling around with the HDMI cords (the one from the cable box to the receiver and the one from the receiver to the TV) and I noticed it seemed to be the HDMI output. I thought it was the HDMI cable itself, but when I tried a different cable it still kept doing it. If I stand there and move it around while it's plugged in, I can get to the point where it is supposed to be at, but I have to stand there and hold it in place and apply pressure to it in order for it to work. When I tried my BD player also through the receiver all I get is the music but none of the dialogue.
    My question is, what exactly is wrong and how can I fix this?
    canada
    Might need to get it repaired,sounds like(sorry for the pun)you bent the hdmi plug and loosened the connections inside.
  3. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Sounds like an intermittent connection in an HDMI cable. I had a similar problem when I bent an HDMI cable into too small a radius behind a TV. I had to replace the cable.
    http://www.kiva.org/about
    canada
    He already said he tried a different cable.
  5. Actually I redid all the speaker wires and now everything seems to work fine.
    Thanks though
