I know there is a lot of discussion on this board about converting from PAL to NTSC, but I am not seeing anything about a quick way to find out whether a DVD-R/+R is PAL or NTSC. As far as I can tell VLC doesn't show framerate under the more information bar. I can extract files and MyDVDEdit will provide the information and the same is true for MPEGStreamclip. But is there a program or a way to know this information without extracting a VOB or a VIDEO_TS folder?
If your discs are DVD-R/+R, then you have unencrypted media. Drop the first VOB of the title onto MPEG Streamclip and then, when it opens it, "get info" (Cmd-I). You'll see the information you seek.
There are various ways to do this. The free version of the Tecoltd Bitrate Viewer will tell you if you open a VOB with it. Actually, it gives you the resolution and frames per second, but you can figure it out from that.
Nope; that's Windoze. We're on a Mac here.Originally Posted by jman98
no need to extract, just double click on a .IFO (or .BUP) located inside the VIDEO_TS inside your DVD, to launched MyDVDEdit.Originally Posted by danielmak
you won't be able to modify the DVD, but no concern to read informations. So, that's very quick!
byeFor DVD, iPad, HD, connected TV, … iMovie & FCPX? MovieConverter-Studio 3 (01/24/2015) - Handle your camcorder's videos? even in 60p or 60i? do a slow-motion? MovieCam.
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 6th Dec 2009, 00:31 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 22:43 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 12:19 -
Quick question - PAL Menu when converting NTSC Xvid
By Azza_b in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 16th Oct 2007, 12:46
