I have a DVD player Philips dvp 3350 (not 3350V).I checked the hack on this site,only for me it doesn't work.
I think I followed the instructions provided in this site and I downloaded a file wich I burnt into a CD,only if I insert the CD in the player it reads unknown and nothing happens.maybe my DVD player bought in Italy is a new type or maybe I made some mistake.
Is there any difference between 3350 and 3350V?
Thanks for yuor help
Marco
	Why did you burn a disc? If a Philips DVD player can be made region free, you only need to enter a code with your remote control. You use a disc to change firmware, NOT to make it region free.
 Here is a link to the region free method for the 3350H player. Maybe it will work.
 https://www.videohelp.com/dvdhacks/philips-dvdr3350h/7080
	Hi!
 It's me again.Unfortunately i've tried and tried but to no avail...
 Those hack don't work on my player.I also have a different type of remote (there's no DVD button).
 I still think my player's a new type of sorts or maybe a european version that requires a different hack...
 Thanks anyway
 Marco
	Some DVD players can never be hacked. And sometimes manufacturers change the hardware during production and these changes break hacks that worked in the past. There may not be a hack for your player.
	Here you can find a firmware for this player:Originally Posted by mlovisetto
 http://vb6rocod.euracks.com/dvp3350_12.php
 If not work, rename file DVP3350_12_V32.bin to DVP3350_12.bin.
 For region free enter setup -->>> preference page, enter 138931 and then set to "0".
  Hack works! Philips 3350By mlovisetto in forum DVD & Blu-ray PlayersReplies: 1Last Post: 26th Aug 2009, 15:05
  Region Code Hack for Philips DVP 3005By luelma in forum DVD & Blu-ray PlayersReplies: 1Last Post: 22nd Aug 2009, 12:17
  PHILIPS DVP 5996 and DVP 5986 QueriesBy anirban in forum DVD & Blu-ray PlayersReplies: 1Last Post: 23rd Sep 2008, 18:32
  New to board-hack for Philips dvp 3150v?By sarah26 in forum DVD RippingReplies: 0Last Post: 15th May 2008, 21:01
  Philips DVP 5140 or DVP 642/37, which is better?By Amuse in forum DVD & Blu-ray PlayersReplies: 2Last Post: 2nd Feb 2008, 17:26
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
