Ok OK! Let me calm myself down. Here's the problem:
I'm trying to burn 4 lotr cds. I merged them into on huge movie and then cut them at more appropriate times. I used BBMpeg to cut the movie and I told it that the total disk size would be 780 megs to be safe. But, when I burn it, everything seems to be fine until the last 10 seconds when it chops and then stops. It does this on both my standalone DVD player and WinDVD. I have no idea what the problem is!
If you need to know, I compiled the SVCD with chapters using TSCV and then burned the image with fireburner. My burner is a 5 day old TDK VeloCD 32/10/40x. I would appreciate any help and please send some soon. It's possible I won't sleep until I fix this.
Nevermind! If anyone was trying to find an answer to my problem, I apologize for wasting your time. The problem was that stupid program called FireBurn. I used the CDRDAO built in TSCV and it worked just fine.
New Hard drive messes up my video
By PhoneMatt in forum ComputerReplies: 2Last Post: 27th Aug 2011, 19:25 -
low end quadro is 5 times faster than high end gaming card
By deadrats in forum ComputerReplies: 4Last Post: 7th Apr 2011, 15:42 -
MP4 messes up the brightness
By midnait in forum Video ConversionReplies: 4Last Post: 23rd Jun 2009, 12:27 -
Xvid messes up when widescreen
By crt in forum Video ConversionReplies: 1Last Post: 4th Nov 2008, 06:11 -
Vobsub messes up aspect ratio in MPC
By cheerful in forum Software PlayingReplies: 0Last Post: 2nd Dec 2007, 11:04
