    Feb 2005
    Canada
    I was in the middle of downloading a live stream and suddenly my PC's power went out and now I'm left with a "no ending" flv file and even the best MPC HC would only play the 1st 3 mins or so. VirtualDub, Avidemux and even GetFLV could not do anything to it. I know for sure the video is in there cause in the process of downloading, I copied/"make a duplicate while it was downloading) that file when it was at about 80MB (the complete file is about 150MB) and I could view the video. I don't care about the audio part....I think somehow this file is missing all the start/end/bit/frame rates etc.....how can I get this file to play? or how best to try to recover this file?
    Thanks in advance
    General
    Complete name D:\Temp 8-5-2009.flv
    Format : Flash Video
    File size : 158 MiB
    Duration : 1h 41mn
    Overall bit rate : 217 Kbps
    Video
    Format : H.263
    Duration : 1h 41mn
    Bit rate : 202 Kbps
    Width : 320 pixels
    Height : 240 pixels
    Display aspect ratio : 4:3
    Frame rate mode : Constant
    Frame rate : 66.667 fps
    Bits/(Pixel*Frame) : 0.039
    Stream size : 147 MiB (93%)
  2. Member Alex_ander's Avatar
    Oct 2006
    Russian Federation
    Try free Applian FLVPlayer. Sometimes flv files get downloaded without proper header. I had such a file marked on youtube as 'embedding disabled by user request'. Nothing on my system could play that file or identify its properties. That player managed to play it.
    http://applian.com/flvplayer/
    Feb 2005
    Canada
    Thanks Alex, FLVPlayer couldn't play it either (same as MPC HC, VLC, SMPLayer...only playing the 1st 3 mins)....oh btw that clip was downloaded using Applian's Replay Media Catcher!
    Any other suggestions? Thanks.
