There is a small beam of light coming from a window and falls on the face of a person. As the person moves his head, a small spot of light moves around his forehead and chicks. Is there an easy way to remove this? Otherwise it was a good take of the video.
Can you paint it out with AE or Final Cut?
There are no problems - only chances to excel.
-- Unknown -
I know Photoshop. I don't know AE or Final Cut.
Isn't there a way to define an area in the video (where the head is) and then do color adjustment just for the particular colors of the spot, to resemble more to the rest of the skin? I mean something like the process I would do in Photoshop, but do it in Vegas. -
You could do it with a mask or adjusment layer, if you want to limit the area
What kind of a spot are you talking about here? How big?
Does the light glow affect other objects? if so, it's going to be very difficult to make it look "real"
If it's a tiny spot with no light transmission or bleed to other objects, using the clone stamp tool might be an option (AE has one that works similar to photoshop)
You can do this in photoshop and re-assemble the png sequence as a video (e.g. with avisynth , vdub) , AE just makes the process a bit easier -
Video has very limited dynamic range. If the sunlight caused white clipping, it will be difficult to correct. The method is called "rotoscoping" and can be done frame by frame from Photoshop.
http://www.google.com/search?hl=en&q=rotoscope+photoshop&aq=4&oq=Rotoscop&aqi=g10Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
it is a small area, the size of a human eye. I will look into rotoscope. Thanks
Small areas can be fixed with the clone brush as said above.Originally Posted by bobpeteRecommends: Kiva.org - Loans that change lives.
Need help with face-replacement in a video.
By surferadi96 in forum EditingReplies: 10Last Post: 10th Jan 2012, 10:49 -
G-Spot says its 4:3, but its really 16:9
By Toastie in forum Video ConversionReplies: 18Last Post: 22nd Nov 2011, 07:54 -
With which software can I censore somebody's face on a video?
By szalaikornel in forum EditingReplies: 7Last Post: 14th Feb 2009, 13:17 -
video of break in, can't see face
By minidrag in forum RestorationReplies: 20Last Post: 5th Nov 2008, 18:17 -
G-Spot Help
By serf423 in forum Newbie / General discussionsReplies: 5Last Post: 31st Mar 2008, 09:07
