If I do a '-vn' it will create FLV with just audio with no problems, so issue must be in WMV3 codec. If I do a ffmpeg -formats it will show a 'D V' for WMV3 - Am I missing any parameters to make this work? Do I need a custom/special build to get WMV3 to decode? I spun my wheels all day trying a variety of things - and pointers would be helpful.
C:\Documents and Settings\batwings\Desktop\Temp\ffmpeg-18639>"C:\Documents and S
ettings\batwings\Desktop\Temp\ffmpeg-18639\ffmpeg" -i mc3100.wmv mc3100.flv
FFmpeg version SVN-r18639, Copyright (c) 2000-2009 Fabrice Bellard, et al.
configuration: --enable-memalign-hack --enable-postproc --enable-gpl --enable-
libfaac --enable-libfaad --enable-libgsm --enable-libmp3lame --enable-libvorbis
--enable-libtheora --enable-libx264 --enable-libxvid --disable-ffserver --enable
-avisynth --enable-pthreads
libavutil 50. 3. 0 / 50. 3. 0
libavcodec 52.27. 0 / 52.27. 0
libavformat 52.32. 0 / 52.32. 0
libavdevice 52. 2. 0 / 52. 2. 0
libswscale 0. 7. 1 / 0. 7. 1
libpostproc 51. 2. 0 / 51. 2. 0
built on Apr 21 2009 13:44:38, gcc: 4.2.4 (TDM-1 for MinGW)
Input #0, asf, from 'mc3100.wmv':
Duration: 00:54:05.47, start: 3.000000, bitrate: 93 kb/s
Stream #0.0: Audio: wmav2, 44100 Hz, mono, s16, 48 kb/s
Stream #0.1: Video: wmv3, 640x480, 3160 kb/s, 1k tbr, 1k tbn, 1k tbc
File 'mc3100.flv' already exists. Overwrite ? [y/N] y
swScaler: Unknown format is not supported as input pixel format
Cannot get resampling context
[Help] wmv to flv with ffmpeg
By Nightslk in forum Video ConversionReplies: 2Last Post: 4th Aug 2009, 13:52 -
ffmpeg wmv -> flv convertion problems
By rolikoff in forum LinuxReplies: 3Last Post: 17th Mar 2009, 05:39 -
wmv to flv - 3 possible conversion with ffmpeg- difficult choice
By bmb in forum Video ConversionReplies: 0Last Post: 1st Oct 2007, 16:00 -
Need a little help here (wmv/mov to flv with ffmpeg)
By yeauxyo in forum Video ConversionReplies: 1Last Post: 10th Jul 2007, 00:08
