Hey, I'd like to know what is the most accepted codec pack for download out there since I my computer was previously filled with many of them (K-Lite Codec Pack, Combined Community Codec Pack, etc.) and now I have decided to uninstall all of them!
Thanks!
Results 1 to 27 of 27
Just install the necessary codecs such as xvid and haali media splitter,codecs packs install way too many codecs and can screw up media playback due to conflicting codecs.Also you can install ffdshow which contains the codecs needed.
Ohh, okay! I get it! I'm using Media Player Classic and I'd like to know how to make those ffdshow little icons (video decoder and audio decoder) appear on the tray everytime I load a movie or something - I just love to watch the bitrate numbers from there, hehe.
Thanks. -
Ohh, okay! I've just downloaded the Home Cinema player now, thanks!Originally Posted by jagabo
Now I'd like to know which codecs do you guys prefer in terms of output quality: the built-in from MPCHC or latest ffdshow?
Thanks! -
If all that is needed is video playback (no encoding), then you can simply use the video players that use internal codecs (VLC Player, GOM Player, etc...).
No need to install any codecs. -
Sure, talk to the hundreds of people who've posted here over the years with problems created by K-Lite.Originally Posted by Xpenguin17
What do they do then? Because when I had a bunch of installed codecs here (I didn't even know what I was doing in fact, lol) MPC sometimes would just not play some basic .AVI or .MPEG files. It showed format not supported or about not being able to do something about graphs, can't remember well.Originally Posted by Xpenguin17
They install in a pre-established pattern that may override your existing installed codecs. The preferred splitter, merits and decoder choice become set by the codec pack, especially if you do the default install and don't manually go through each option in the custom install. In addition, they install lots of "junk" that you don't need. So they can cause "conflicts" (e.g. say you have a capture device or other hardware that depends on a specific directshow chain or filter, they often get replaced by the codec pack, making it non functional).
It's usually recommended to install just what you need, when you need it. It's easier to debug and troubleshoot when you do have problems this way. With a codec pack you have more difficulty because of the 100's of splitter, decoders installed.
You can use graphstudio and/or radlight filter manager to help sort out directshow codecs, and vcswap to help sort out vfw type codecs. -
Yes, they can, and often do. You are wrong. I can only assume you've been lucky enough to not notice (but I bet your system still has problems you've not yet witnessed!)Originally Posted by Xpenguin17Want my help? Ask here! (not via PM!)
Bet you use k-lite. :POriginally Posted by Xpenguin17I think,therefore i am a hamster.
A good splitter renders the video thru Directshow and flips thru alternative filters only when necessary. K-Lite codec pack is well set up -- I've used it since 2003 and never had any problems with decoding clips nor system problems. If it does manage to halt your system or rape essential system files, it isn't hard to do a system restore or Windows repair.
Finding and downloading the best versions of individual codecs and setting up custom splitters is a mindfuck for newbs. No reason to give them more shit than they already need to deal with. Then again, some newbs are real retards who can't use a nail clipper without injuring themselves, so giving them a playground of codecs may not be the best idea either.
Meh..... -
One may not notice the problems caused by K-lite for weeks. By then it may be too late, or a huge pain, to do a system restore. Especially if any other video software has been installed and/or uninstalled in the interim.
Use ffdshow instead. It contains all the decoders that most people will need. -
My friend, you are 1 year behind.o I need to update my ffdshow if it's tryouts revision 2364 from Nov 24 2008?
If so, where from, please?
I like to stay up to date
The last version is r3065 2009-09-02 and you can download it here: https://www.videohelp.com/tools/ffdshow -
I use the Combined Community Codec Pack (which is for the sort of people who used to use DefilerPak). Stripped-down pack consisting mainly of MPC-HC, ffdshow-tryouts and Haali's splitter, maintained by some very experienced encoder folks.
K-Lite has gotten somewhat better nowadays, unlike the early years when it was a horrible and conflicting mess. (Of course, that's just what I've heard.) I still wouldn't use it, though. -
Thanks, updated OK and doesn't seem to have broken anything
Hasn't fixed anything either
On a fresh install the K-Lite Codec Pack (Standard) is a good choice. It will enable you to play almost anything, including DVDs in WMP. Folks always talk about all the stuff it K-Lite installs. There is no forced mass install. The installer gives you a choice of what you actually want installed. I wouldn't want to use it on a previously working system that has developed codec issues, but for a fresh install the Standard pack is a good starting point with well chosen, compatible components. It will eliminate 99% of the posts that start with "I downloaded this file and can't get it to play".
Contents of K-Lite Codec Pack (Standard)
Below you can find a list of all components that are included in the pack.
Contents of version 5.1.0:
Player:
* Media Player Classic Homecinema [version 1.2.1008.0]
ffdshow:
* ffdshow [revision 3065]
DirectShow video decoding filters:
* MPEG-2 (Cyberlink) [version 8.4.0.615]
DirectShow source filters:
* Haali Media Splitter [version 1.9.42.1]
* MP4 splitter (Gabest) [version 1.3.1268.0]
* FLV splitter (Gabest) [version 1.3.1268.0]
* MPEG PS/TS splitter (Gabest) [version 1.3.1268.0]
DirectShow subtitle filter:
* DirectVobSub (a.k.a. VSFilter) [version 2.39.5.2]
Other filters:
* Haali Video Renderer [version 1.9.42.1]
Tools:
* Codec Tweak Tool [version 3.1.0]
* MediaInfo Lite [version 0.7.20]
Their FAQ also contains many good explanations and solutions for a multitude of problems.
http://www.codecguide.com/faq.htm
Their explanation of the difference between filters and codecs is also worth a read. -
What's broken?
Well, I'm trying to get AVCHD Lite (720p25) to work well in a free Windows NLE. As WMM on my system doesn't do HD and is limited in formats, and I don't fancy the new Windows Live MM, I'm currently using VideoPad instead. But, as being discussed here https://forum.videohelp.com/topic372774.html I'm having trouble getting things just as I'd like.
Thanks -
MysticE wrote:
OK.Contents of K-Lite Codec Pack (Standard)
Player:
50% OK. The latest versions of ffdshow have brought us
more bugs than solutions.
Should be DScaler_5.DirectShow video decoding filters:
If Haali is set to NOT disable the internal MKV splitter of MPC,DirectShow source filters:
then that's OK.
Version 2.39 still has a formatting issue with embedded .SRT streams.
OK.Other filters:
Tools:
What is the best Codec Pack?
By cim in forum Software PlayingReplies: 84Last Post: 8th Jul 2012, 12:45 -
Klite Codec Pack
By pepegot1 in forum EditingReplies: 6Last Post: 2nd Feb 2012, 22:39 -
K lite codec pack
By Pumkinhead in forum Newbie / General discussionsReplies: 14Last Post: 26th Oct 2010, 14:12 -
xp service pack 3 download? Were can i get this 4 3 ?????????
By xJensbigproblemx in forum ComputerReplies: 22Last Post: 1st Jul 2010, 11:02 -
Codec Pack selection?
By therock003 in forum Newbie / General discussionsReplies: 4Last Post: 21st Oct 2007, 11:50
