Hi,
I am new to the whole concept of HDMI. I just got a Philips DVP5990 which I hooked up to my HDTV via HDMI and audio cables. When I want to set the DVD player to progressive, it is grayed out and the manual says that I would need the component connection for setting the picture to progressive.
Does that mean (a) that the player is set to progressive automatically whenever I use HDMI, or (b) that I should use the component connection and not HDMI if I want the progressive scan, or (c) another answer?
Matt
I think it means only that you cannot change the setting via anything but component.
The 5990 can output progressive to an HDTV. Go to the HDMI Setup page and set the resolution to 720p or 1080p. Not all HDTVs will accept 1080p so that may be disabled. After doing this the Progressive option on the general settings page will be gray but the player will be putting out progressive video. My HDTV can report the input signal and when I do this it reports: 1920x1080p 60 Hz.
I think if you're using the HDMI cable, the video is progressive by nature.
Also, the audio is transmitted via the HDMI cable to the HDTV, so you don't need to use separate audio cables.Frank Zappa: "People wouldn't know a good movie if it smacked 'em in the face." -
It's progressive if you choose 720p or 1080p. It's interlaced if you choose 1080i.Originally Posted by bmwracer
Philips DVP5990 Issue
By TheStranges in forum DVD & Blu-ray PlayersReplies: 3Last Post: 16th Dec 2010, 23:56 -
Philips dvp5990
By tqworld in forum DVD & Blu-ray PlayersReplies: 4Last Post: 18th Jun 2010, 18:24 -
Philips DVP5990/F7 freezes
By flyboynm in forum DVD & Blu-ray PlayersReplies: 0Last Post: 7th Mar 2010, 16:46 -
Philips DVP5990 DTS Via HDMI
By avkhatri in forum DVD & Blu-ray PlayersReplies: 6Last Post: 29th Jul 2009, 13:33 -
Philips DVP5990 (80,60)
By hujercz in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Dec 2008, 04:57
