Well, I have a LITTLE experience with a couple of the Ulead programs, but not really much.
The problem:
I am trying to edit out a scene from a video that I have copied to my hard drive. I am using DVD MoveiFactory SE (Good, bad or indifferent, I don't know). While playing it back, it appears to "jump" steadily at the rate of about twice per second. I suspect that this must be something fairly common, but I don't know what to search for to try to find a solution to this problem. I have searched the forums, but have not found it yet. I don't really think it is specific to Ulead, or at least to the specific version I am using as I have tried three different versions of Ulead and also noticed this same behavior when I used Stoik video converter to convert avi to wmv.
I don't know if it has to do with my o/s, or a driver issue. I can play any utube video fine. I can also play dvd's in the dvd player just fine. But not when I try to work with the video.
Any help here would be greatly appreciated.
Thanks in advance
What was your source video? Are you saying playback is jerky in MovieFactory or in your DVD player after making a DVD?
Hi,
Thanks for the reply. The source is a vob file on the hard drive. The problem is in Moviefactory or possibly something in a driver I think. It could not be the player since this is all on the hard drive.
Thanks -
Does the video play fast for a bit then pause, then play fast again and pause, about twice a second? That is a miscommunication between the MPEG splitter and the MPEG decoder when playing 23.976 fps MPEG with 3:2 pulldown flags. That shouldn't matter once you burn a DVD. You could also try converting the VOB file to an MPG file. VOB2MPG, or a simple remux with TMPGEnc Free.
DVD MF is an authoring and burning program with limited editing capability. It will accept vob renamed to mpg and author just fine.
Video Studio is Ulead's editng product.
You also don't mention what version of MF you are trying, earlier versions don't work on vista. "SE" versions are usually versions bundled with hardware and may have some features missing from the full version.
If you want to cut out some scenes and reauthor a dvd, the easiest solution is to use an mpeg editor like videoredo and DVD MF to reauthor a dvd if needed. -
clausont, in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules:
Try to choose a subject that describes your topic.
Please do not use topic subjects like Help me!!! or Problems.
Moderator redwudz
And welcome to our forums. -
Jagabo - This sounds like what is happening, however, when I played the final clips, whether vob or mpeg2 the jumping continues in the finished video.
I have downloaded VOB2MEG and will give that a try. Thanks for that information - I had not heard of those programs.
qpskfec - (are you an amateur radio operator? Just curious by your username.) I said I had used Moviefactory SE, I was wrong there. I used Video Studio SE which came bundled with an Ezcap capture device. Also tried MF 6.0, MF 2.5 and Video Studio 7.0 which are all that I have.
I have the same results regardless of what program I am using. I still have the same problem if I am trying to convert an avi or mpg in Stoik Video converter to wmv.
redwudz - my apology. In the future I certainly will use a more descriptive subject title. Thank you for changing it this time. -
Originally Posted by clausont
BD-R jumps through chapters
By dingo2000 in forum Blu-ray RippingReplies: 15Last Post: 16th Sep 2011, 12:58 -
Corel Video Studio Pro x4 jumps when capturing?
By TheKillerQueen in forum Capturing and VCRReplies: 3Last Post: 17th Apr 2011, 10:01 -
Video frame rate question
By Ramza126 in forum Newbie / General discussionsReplies: 4Last Post: 11th Jun 2008, 18:57 -
Data rate for HD video
By spandau in forum EditingReplies: 3Last Post: 21st Nov 2007, 13:23 -
Video rendering rate?
By capman21 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 9th May 2007, 22:57
