Hey people. I've been encoding my DVD rips to .mov format to my mac so that I can play them back quickly and yada yada yada...
However, some of the files when imported into Streamclip twitch. As in, the go forward two frames then back one. It makes the whole thing really annoying. The twitching only occurs on the beginning parts of some of the DVD rips. I've looked all over the internet and I can't find an answer anywhere. So I just joined in hopes that someone will be able to help me out. The audio on those rips also is messed up. (It's off sync for some reason. I don't so much mind the audio issue but the twitching is just unbearable.)
If you can help I thank you greatly ;D
Used MacTheRipper to obtain VOBs (Not sure if that effects anything)
Yes it does. Which Version of MTR are you using?
the latest is MTR 3.0r14m, which handles most of the newer
copyguard schemes.
also when importing into MpegStreamclip after ripping with the newest MTR,
are you "Fixing the TimeCode Breaks" that often occur with ArCCos
copy protected DVDs? if not you should as that will smooth out
playback so that MpegStreamclip knows how the video should
be played back ( linear wise)."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User
Converting .VOB files to MPEG4 with Streamclip and MPEG2 Playback Component
By MLK3329 in forum Video ConversionReplies: 4Last Post: 7th Mar 2011, 14:51 -
Mpeg Streamclip VOB -> MP4 frozen frame issue
By smmuck in forum Video ConversionReplies: 0Last Post: 16th Oct 2010, 19:16 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 18:12 -
MPEG Streamclip VRO Files
By bz186 in forum EditingReplies: 0Last Post: 10th Sep 2009, 16:06 -
Trouble converting from VOB with MPEG Streamclip
By headless chicken in forum MacReplies: 3Last Post: 3rd Jan 2008, 10:42
