Results 1 to 10 of 10
    Nov 2008
    I am TRYING to take 3/4 of a football game using flash media card and loading into my computer. Then I am trying to take the last quarter and trying to make a single dvd! (doing it this way to save time?) Anyways, I WAS ABLE (woohoo!) to make a dvd that plays on my computer but when i place it into my dvd player it recognizes it as a photo dvd and wont play?! I was using imgburn to combine the files from the flash cards..What is this total newbie doing wrong?
    You are in breach of the forum rules and are being issued with a formal warning. You were asked to use a descriptive title with your last thread.
    / Moderator redwudz
  2. dvd players expect a disc in a certain format to play. it can't just be the files off a cam.
    you need to encode to dvd spec mpeg-2 and then author them into the correct files and folders.
    if you need the software you might try dvd filck as it's free. for a cheap paid program convertxtodvd is easy and works ok.
    Nov 2008
    Thank you Mini! I d/l'ed dvdflick and in the guide it says "step 1. Add titles using the add title button. When I do that a bunch of files pop up. I find my flash media and it comes up as SD_Video? Which will not "open" up into the "add titles here" button? Im soo confused haha
  4. what format are your files in? use mediainfo on one and paste the output from the text view here.
    it might help to copy the flash card files to your hard drive first.
    Nov 2008
    Says its a .MOD file?
    Nov 2008
    I read somewhere that Sony shoots video in mpeg-2 format? Is this true? So Sony camcorders d/l into a computer in mpeg-2?
    Aug 2005
    Palo Alto, California USA
    You should start by reading "What is DVD" in the upper left hand corner of this page. If you scroll toward the bottom, you will see a summary of what DVD-compliant specs are. To make a DVD that is playable in standalone players, your video must comply to those specs, and the disc must be authored in a certain way.
  8. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Use mpeg-streamclip to convert your MOD files to mpeg-2 files (no re-encoding) and go from there
    Read my blog here.
    Nov 2008
    thank you gunslinger! tried it and it works great...guess there isnt a faster way to convert though eh?
  10. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    If it isn't converting then it should take only a minute or two per clip, depending on size. How much quicker do you want ?
    Read my blog here.
