hi im trying to make mkv to usb avchd for ps3 but it doesnt work. I copied the AVCHD folder to root of USB. However PS3 doesnt recognize the AVCHD folder from the usb as AVCHD disc when I click the (X) button. I clicked the triangle button and then had to drill down to the AVCHD/BDMV/STREAM folder to play the m2ts/mts file.
I was expecting PS3 will play the AVCHD folder as if it found AVCHD disc. Am I missing something here?
i followed these steps.. http://www.bitburners.com/articles/convert-mkv-to-usb-avchd-for-playstation-3-using-mkv2vob/4384/
OK I haven't checked the steps you posted but what format is the usb drive in? If it is NTFS the ps3 won't recognize it. It must be fat32. Hence the 4gb limit. HOwever there was a post the other day about using multiavchd to create 1gb chunks that will bypass the restriction.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
@caner12:
What tool did you use to create the AVCHD folder?
PS3 will recognize it once it conforms 8.3 filenames format, i.e. INDEX.BDM not index.bdmv.
Browse around for AVCHDManager and convert your folder to PS3/8.3 compliant one. multiAVCHD will make it easier for you of course.Laugh and the world will laugh with you. Cry and you will be alone
My PS3 plays my AVCHD video well.
By jbitakis in forum DVD & Blu-ray PlayersReplies: 6Last Post: 5th Jan 2012, 13:04 -
PS3 Stops Playback of AVCHD?
By tommy2010 in forum Authoring (Blu-ray)Replies: 1Last Post: 15th Dec 2010, 01:38 -
AVCHD DVD and PS3
By DesossiriboNucleicAcid in forum Authoring (Blu-ray)Replies: 4Last Post: 14th Feb 2010, 14:14 -
How to get AVCHD on Harddrive of PS3 without loosing quality
By alex1357 in forum Video ConversionReplies: 2Last Post: 7th Jun 2008, 10:06 -
Why doesnt my DVD play on mac/ps3/dvdplayer?
By chronic777 in forum Authoring (DVD)Replies: 1Last Post: 11th Aug 2007, 12:21
