hallo all :
Is possible to burn /convert avi files direct to computer desktop or direct to jump drive using Toast9 /Mac OSx 10.4.11- skipping DVD media first ?
Cheers in advance
You don't need to use Toast if you want to copy AVIs to a USB drive. Just copy the files to the USB drive normally, in Finder.
Are you trying to place AVIs on the USB/jump drive so that you can, say, watch it on a DivX/Xvid-compatible DVD player, or another computer?If cameras add ten pounds, why would people want to eat them? -
In Toast, instead of using the Burn button, you could do menu File > Save as Disk Image to your hard drive. The disk image file would hold the same information as a DVD-Video disc. This disc image can be mounted as a volume, sort of like a virtual disk. Then you could copy the files (VIDEO_TS folder) from the disk image to the portable drive.
BattyRoy: Do you actually want a DVD-Video disc structure on the jumpdrive, or are you just looking to convert the videos and store those directly to the drive?
desktop computer memory
By wingnut2003 in forum ComputerReplies: 4Last Post: 4th Feb 2010, 05:53 -
Connecting a desktop computer to a TV?
By improvisation in forum Newbie / General discussionsReplies: 16Last Post: 10th Nov 2009, 10:06 -
Direct from DVR to computer hard drive?
By jdcrowley in forum DVD & Blu-ray RecordersReplies: 2Last Post: 29th Sep 2008, 21:08 -
Do you use desktop themes on your computer?
By yoda313 in forum PollsReplies: 16Last Post: 14th Aug 2007, 12:13 -
Capture / Burn direct to drive
By Bob08 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 19th Jul 2007, 15:28
