OK so this is my first post here. I am running into a problem. I am working on editing some video that was given to me by a family member. Problem is that it is in dvd format on a dvd, and I am having trouble ripping it to a file type and compression that can be used in Adobe premier so that I can edit the video down. Please any help would be appreciated.
cheers,
Results 1 to 9 of 9
Try using VOB2MPG and extracting the MPEG video from the VOBs. If Premier accepts that, you can edit, then re-author to a new DVD.
And smallears, in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules:Thanks,Try to choose a subject that describes your topic.
Please do not use topic subjects like Help me!!! or Problems.
Moderator redwudz
And welcome to our forums.
EDIT: Sorry, missed that you were using the Mac OS. Maybe MacTheRipper instead of VOB2MPG. Didn't know Premier ran on a Mac. But I'll move you to the Mac forum where you may get more Mac specific information.
No.
See my edit above. I've moved this thread to the Mac forum where you should be able to get more Mac specific answers.
Also some Mac specific tools here: https://www.videohelp.com/tools/sections/macos-video-tools -
Originally Posted by smallears
This has been discussed many times before and can be found searching the forum:
Here is a most recent version of these steps:
1. Rip Main Feature with MTR.
2. Open the rip with MpegStreamclip, play through to
determine the rip was good, and fix any timecode breaks?
3. Export out to DV Stream.
4. Import into Premiere."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User
Choosing right settings for editing HD .mov files in CS4 Premier-PC environ
By Downing32 in forum Video ConversionReplies: 24Last Post: 28th Jan 2013, 18:36 -
Convert H.264 from my Veho Kuzo to DV AVI for editing in premier 1.5
By guzzuk in forum Video ConversionReplies: 1Last Post: 27th Dec 2009, 05:28 -
Editing AVCHD (M2TS) with Adobe Premier
By rancineb in forum Video ConversionReplies: 33Last Post: 29th Jan 2009, 22:23 -
Codec choices for editing and exporting in Premier
By nhart1001 in forum Video ConversionReplies: 6Last Post: 8th Sep 2008, 19:01 -
Importing/Editing Video with Adobe Premier 6
By Namrepus221 in forum EditingReplies: 10Last Post: 12th May 2008, 22:30
