    Aug 2009
    I have been out of the loop for a while on this subject. I am looking to convert a couple of DivX clips into a single DVD for playback on an older sony standalone player. I searched on this but a lot of the info is a bit old, the newer posts suggest various software, but whats good. What software is worth looking into and whats bloated malware. I dont need wizards and one click solutions, just want trying to avoid going down blind alleys and installing 40 different titles to find the right one. any suggestions.
  2. Banned
    Freedonia
    It's hard to beat HCEnc, which is free. Here's a guide to using a GUI front end to encoding from AVI to DVD using Avi2DVD which in turn uses HCEnc.
    http://www.afterdawn.com/guides/archive/avi_to_dvd_avi2dvd.cfm
    Other non-freeware tools can be used as well, such as ConvertXtoDVD.
  3. Use FitCD to generate an AviSynth script. Encode with HcGUI. All free. About as good results as you can get.
    Aug 2009
    Thanks for the quick replys.. One more question, I'm a bit lost here.
    Right now i'm looking at ConvertXtoDVD and DVDFlick, heres the thing. I have a 5 DivX files of 700 Mb each, (about 3.5Gb) I want to fit all of them on to one DVD 4.7Gb. as a DVD movie, The software is processing the files into larger filesizes, giving me only 2 DivX per DVD. I saw one solution to create a custom size dvd with five files on it (over 6Gb) then running that trough DVD Shrink or the like. Will leave that as a last resort. What can i do here, or am I asking for too much.
  5. file size = bitrate * running time
    If your five videos are too big to fit on a DVD after conversion you have to use a lower bitrate. MPEG 2 encoding is not as efficient as Divx/Xvid. Count on needing twice the bitrate to maintain video quality. Twice the bitrate means twice the file size.
    What's the total running time and resolution of your five videos?
  6. Member PuzZLeR's Avatar
    Oct 2006
    Toronto Canada
    MPEG-2, which DvD uses, isn't optimized for lower bitrates (lower file sizes) like DivX is. Expect less content on a disc to get decent quality.
    EDIT: Just noticed Jagabo posted almost the same time, and some similar points. :P
    I hate VHS. I always did.
