I converted a 16:9 DV file of about 35 minutes to mp4 using WinFF and find the audio is out of sync. Any suggestion on how to prevent this?
If it helps, this is the command line I used. The only thing I changed from the default is the video bitrate upped it to 1700 min 2200 max.
-r 29.97 -vcodec h264 -s 704x384 -aspect 16:9 -flags +loop -cmp +chroma -deblockalpha 0 -deblockbeta 0 -b 1700k -maxrate 2200k -bufsize 4M -bt 256k -refs 1 -bf 3 -coder 1 -me umh -me_range 16 -subq 7 -partitions +parti4x4+parti8x8+partp8x8+partb8x8 -g 250 -keyint_min 25 -level 30 -qmin 10 -qmax 51 -qcomp 0.6 -trellis 2 -sc_threshold 40 -i_qfactor 0.71 -acodec aac -ab 112k -ar 48000 -ac 2
Follow-up - I just converted the same file to Xvid and got the same results.
Originally Posted by MegaTonTerror
That is because H.264 in AVI delays by however many B-frames if you got B-pyramid enabled.
Originally Posted by guns1inger
.smack forehead
When I attached a 256kbps mp3 instead it brought the file size in line.
MP4 to MP4 out-of-sync
By Iwan2learn in forum Video ConversionReplies: 2Last Post: 16th May 2009, 22:43 -
Mp4 sync issue...
By sonnenkind in forum Video ConversionReplies: 8Last Post: 24th Feb 2009, 22:27 -
help guys. out of sync mp4.
By tryvora in forum Video ConversionReplies: 2Last Post: 26th Dec 2008, 10:54 -
mp4 out of sync
By myk in forum Video ConversionReplies: 2Last Post: 15th Mar 2008, 07:34 -
Out of sync on mp4 player
By SonicFusion in forum Newbie / General discussionsReplies: 1Last Post: 16th May 2007, 05:38
