Hey guys!
I'm new here and new into video capturing.
I'm from Brazil and I bought a capture card in the USA (Pinnacle's MovieBox Ultimate)
I installed all the software needed and when I started to capture, the image preview was black and white. I changes the video colors system on my bogth VCRs and on Pinnacle's software but I wasn't lucky.
Is there any way to fix that?
Thank you all for the attention.![]()
What are you capturing from?
An NTSC device will work for NTSC composite or NTSC S-Video but may not work with Brazil's PAL-M system. PAL-M would show as black and white. E-Mail Pinnacle about PAL-M support.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
I'm capturing from a VCR and the tapes were recorded in auto mode...
So you mean that capture cards from US wont capture in color Brazilian tapes?
Not if they are PAL-M. Yes if they are NTSC.Originally Posted by fabitos
Pinnacle may have support for PAL-M in the menus or as a separate model.Recommends: Kiva.org - Loans that change lives.
Have you looked at your Studio software´s settings button in capture mode? The firts tab refers to your source (your moviebox device, firewire card, etc...) there you can select either PAL, SECAM or NTSC (also 4:3/16:9, etc...)
PAL-M is a hybrid of NTSC and Euro PAL.
It is 525 lines, 60Hz and color subcarrier is near 3.58 MHz but color encoding is PAL not NTSC.
Euro PAL has 625 lines, 50 Hz and subcarrier at 4.43 MHz.Recommends: Kiva.org - Loans that change lives.
Help with Virtualdub and Pinnacle MovieBox 710-USB
By cgarai in forum Capturing and VCRReplies: 3Last Post: 7th Apr 2012, 00:14 -
Pinnacle Studio MovieBox Ultimate vs. DVD-recorder
By fabitos in forum Newbie / General discussionsReplies: 6Last Post: 24th Nov 2009, 07:04 -
Limited capture success with Pinnacle MovieBox Plus 510-USB device
By ccooper in forum Capturing and VCRReplies: 4Last Post: 17th Jul 2009, 11:52 -
Pinnacle Ultimate
By sknarberg in forum EditingReplies: 2Last Post: 24th Jun 2008, 05:36 -
Pinnacle Moviebox
By gkoenig in forum Capturing and VCRReplies: 0Last Post: 3rd Jul 2007, 12:36
